Driver Window Question
Old May 22, 2003 | 05:56 AM
tkarrh's Avatar
I replaced the main window switch in my driver door and my driver window still will not work. Is it the motor? All other windows work.
Old May 22, 2003 | 08:05 AM
tkarrh's Avatar
Old May 22, 2003 | 08:08 AM
jjs's Avatar
jjs
Originally posted by tkarrh
Sounds like a motor to me.
Is the replacement switch the correct one for the year of the car and installed properly (backlit if you turn your lights on...to see if it has power)?
Old May 22, 2003 | 08:12 AM
Maxman2000's Avatar
Check fuses and if that's not it, It could either be a bad connection that losened up over time or like the others say, bad motor.
Old May 22, 2003 | 09:45 AM
tecman4's Avatar
You might have to look but the switch might be connected to a relay
Old May 22, 2003 | 10:17 AM
saxdogg's Avatar
Well, depress the switch with the key on and check for power at the motor. This will tell you bad motor or not, go from there.
ARFF
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mario Vegas
Oct 5, 2015 11:10 AM
boomerbrian
Sep 2, 2015 03:46 PM
A32goldylocks
Sep 2, 2015 06:39 AM
