Can you Re-Use DYNAMAT????
Old May 22, 2003 | 02:13 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
i have a trunk kit in my old car... just wondering if you can re use it?
anyone wanna tell me about the peel n seal from home depot?
and can you use too much dynamat?
thanks in advance
Old May 22, 2003 | 02:14 PM
PCGuRu2K's Avatar
There can never be too much.. The more you put it'll be heavy like a ****
Old May 22, 2003 | 02:19 PM
jttaylor155
i dont know why not. i dont think it gets "full" of sound.
or maybe it works like a sponge and gets saturated.
i got it - squeeze it and all the sound will come out and then you can reuse it. (picture that one) god i crack myself up :-)
Old May 22, 2003 | 02:29 PM
2k2PhatMax's Avatar
har har har
so just reheat it and pull...?
Old May 22, 2003 | 02:39 PM
silvermax2k2's Avatar
Originally posted by 2k2PhatMax
har har har
it depends on which type of dynamat you use. there are two types of dynamat. the first being the heat on and stick to the car. in which you can use again, but it will be hard to get it off, and will leave glue marks where you took it off from. the second type is the kind on a roll, and it is just peel of plastic and stick on car w/o any heat. this type would be extremly hard to re-use. i have the kind w/o heating and i tryed to take it off and it took me 5 mins to get it off an inch!!! hopefully you have better luck with the heat kind. also have to be concerned with if the glue will stick as well as it did the first time.
Chris
Old May 22, 2003 | 04:05 PM
iLLin-2k1's Avatar
Don't buy peel-n-seal, its a cheap alternative but, it smells bad.
Old May 22, 2003 | 04:10 PM
WildmanAL's Avatar
I got some stuff called FatMat from Ebay. I wouldn't reuse the stuff. I don't think by reusing it that it would stick too good to the new surface and would just fall off all the time.
Old May 22, 2003 | 04:45 PM
spta97's Avatar
It smells like tar for a day or 2 but then it goes away. This stuff is awesome and comes in rolls (6" x 20'?) for like $14. It gave my trunk the dampening it needed.
Old May 22, 2003 | 04:47 PM
iLLin-2k1's Avatar
How long have you had it?
Old May 22, 2003 | 09:59 PM
2k2PhatMax's Avatar
so for 14 bucks i can do how much of my car...?? with the peal n seal the smell goes away for sure???
Old May 23, 2003 | 05:43 AM
spta97's Avatar
6 months or so.
Old May 23, 2003 | 05:49 AM
NT2SHBBY
6 months or so.
looks like I'm hittin up Lowes in Garden City tonite..... thanks Spta!
Old May 23, 2003 | 07:03 AM
spta97's Avatar
It took me 2 1/2 rolls I believe to finish my trunk (one layer). Here's what I did:
Peal & Seal Trunk
1) Remove trunk clips to take out liner. Use a felt tip marker to mark the holes where the clips / screws go back in. Use a different symbol for push in clips (ie: "0") and screw in (ie: "+").
2) Clean the whole trunk with rubbing alcohol and clean cloth. Then wipe it down with a water damp cloth and let dry.
3) Figure out the length and shape of the section you are doing before you take of the paper that exposes the adheasive backing.
4) Heat up the section of sheet metal with a heat gun (this was more important when I did it in the winter).
5) Stick down the Peal & Seal and heat the stuff up until it gets nice and tacky (it might even liquify) and mash it to the sheet metal and get it into all the nooks & crannies. But I can't stress this enough - WEAR WORK GLOVES!!!!
By doing this you will be redirecting all those lost sound waves into the cabin (and at your rear deck). If you though your rear deck rattled bad before, it will really suck now. I got a foam mattress pad (aka: egg crates) and cut it to size and shoved it under (about $10 at Wal*Mart or K-Mart (a twin size will do). This combo solved about 95% of the rattling inside the car. Total cost was about $50. Lowes carried the Peal & Seal, Home Depot in LI did not.
The trunk smelled for about a day or 2 but it went away. That is, unless I stink
Good luck!
*edit* - ps: There is NO WAY IN HELL you are going to reuse this stuff...or get it off for that matter. Once the heat gun gets done with it it is pretty much part of the car.
Matt93SE
May 24, 2019 02:58 PM
killaSin11
Mar 28, 2002 10:49 AM
MichaelAE
Jan 2, 2002 01:15 PM
gma6188
Oct 11, 2001 11:52 PM
TurDz
Sep 8, 2001 07:47 AM
