Mobil 1 M1-118 vs. M1-110 oil filter
Old May 23, 2003 | 10:23 AM
RxMan's Avatar
Mobil 1 M1-108 vs. M1-110 oil filter
Autozone recommends the M1-108 but others have said use the M1-110. What's the difference. I bought the 108 today. This isn't an Autozone computer error or anything is it?
Old May 23, 2003 | 10:33 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Mobil 1 M1-118 vs. M1-110 oil filter
Which motor do you have. Someone on this board tried the 108 and ran into an interference issue. In otherwords it physically would not fit into the space.
I have the 3.0 and use the 110.
Old May 23, 2003 | 10:35 AM
AKM2k5's Avatar
whats the 3.5 supposed to be?
Old May 23, 2003 | 10:45 AM
BiggD23
I still haven't found a store that sells them yet, so I haven't had a chance to try it myself, but NT2SHBBY uses the M1-110 in his 3.5 with no issues. He's the one I got the part # from.
Old May 23, 2003 | 10:52 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Use the M1-110.
The bypass valve is rated the same at 14psi, and basically the only real differences are the actual size and smaller filtration area for the M1-108 to fit in the SR20DE engine compartments.
M1-110s work on all VQ30 and VQ35 models.
Note:
For VQ35DE owners, use the M1-105 due to its better top end bypass valve design. It's better constructed than the bypass valve of the M1-108 and M1-110 filters.
Old May 23, 2003 | 12:08 PM
BiggD23
OK, this is probably a dumb question...but what is the difference (if any) between VQ35 and VQ35DE? I have an automatic 2003 SE, so does that mean I should use the M1-105?
Old May 23, 2003 | 12:14 PM
NT2SHBBY
yeah I use the M1-110...no problems..car runs better with synthetic
Old May 23, 2003 | 12:51 PM
PCGuRu2K's Avatar
Old Jun 17, 2008 | 07:39 PM
gotendbz1's Avatar
old bump, i just got a m1-108, should i use this one or return for a m1-110, any difference or just peopl ebeing parnoid?>
Old Jun 17, 2008 | 08:35 PM
jasonmax's Avatar
110 FTW
Old Jun 18, 2008 | 04:06 AM
vball_max's Avatar
I believe you have this backwards......the 110 is longer than the 108 so if they had issues, they had it with the 110.
I used to use the 105 which is much larger in diameter, which I believe had clearance issues with some cars, not mine though. I dont believe the 105 is available anymore, so I use the 110 now. No clearance issues at all. I believe that the 108 is what is recommended for our cars, but it has been shown here on the org that the 110 works better.
Old Jun 18, 2008 | 05:32 AM
knight_yyz's Avatar
Toolie
m1-105 is the larger one for the vq35, which I have only been able to find at autozone
Old Jun 18, 2008 | 06:52 AM
jasonmax's Avatar
the 105 has nolonger been continued, so 110 will be your chioce.
Old Jun 18, 2008 | 06:53 AM
knight_yyz's Avatar
Toolie
good thing I stocked up on them then
Old Jun 18, 2008 | 06:59 AM
jasonmax's Avatar
I've heard that the bypass valve on m105 needs higher presure to open, which is not good for the engine when cold.
my03maxima
Jul 28, 2024 07:40 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
