Guage Bezels
Old May 27, 2003 | 08:01 AM
bdog's Avatar
Guage Bezels
I just bought aluminum guage bezels any1 know hot to install them. (open up the dash pretty much)?
NT2SHBBY
peal 3M tape and stick ontop of clear plastic over gauges
Old May 27, 2003 | 08:05 AM
Maxman2000's Avatar
You have to take the clear plastic off. If ya don't, it won't look right.
Old May 27, 2003 | 08:06 AM
255HP_03_SE's Avatar
You have to first remove the steering column cover (this is 3 or 4 screws underneath the steering column). There is an upper piece and a lower piece.
Next, you remove the two screws holding the gauge molding. This will slide out and you need to use a little finesse to get it past the steering wheel.
Then you remove the three retaining screws that hold the cluster on the mounts.
Take the cluster down and if you need more room, remove the connectors from the back (take caution in remembering where they go!) so you can freely handle the cluster.
Then carefully remove the plastic cover (by popping the tabs out of the sockets) and use the 3M adhesive backing to apply the gauge bezel to the cluster face.
NOTE: LINE UP THE BEZEL BEFORE TAKING OFF THE TAPE BACKING! You will need to SLOWLY place the CENTER of the bezel on FIRST, then work each side down and GENTLY press down to ensure that the adhesive will stick.
Then put it back together in reverse order.
-R
Old May 27, 2003 | 08:30 AM
bdog's Avatar
Thanx 255hp.
Matt93SE
Apr 8, 2018 09:23 AM
rnb754
Sep 14, 2015 11:39 PM
Violator
Sep 9, 2015 10:14 AM
95Maxi
Aug 25, 2015 08:01 PM
