Dashboard clock
Old May 30, 2003 | 06:15 PM
mykmar10's Avatar
Dashboard clock
What's crackin' Org. members,
Someone on the Org. was able to disable thier dim feature on the dash clock (the feature that dims the clock when the paking lights are on). How did they do it? I want to do the same with my clock.
Old May 30, 2003 | 07:09 PM
jeepik's Avatar
on my 2k2, if you tur nthe dimmer switch all the way, to its birghtest, then it will click that means that the dash clock radio and a/c will not dim when the lights are on
dont know if that helps or not
Old May 30, 2003 | 07:33 PM
Corelventura's Avatar
if you look closely the dash WILL dim if the headlight are ON even if on the max setting
Old May 30, 2003 | 09:42 PM
Rob'sAE's Avatar
You're Faster, I'm Better
Re: Dashboard clock
I just did it on my 2001, it should be the same on your 2003. Pop the clock out carefully, and disable the red wire with blue stripe any way you see fit. If you are mechanicly inclined you can pull out the little harness and pull the entire wire out of the harness without any damage or cutting of wires. I did this so I could return it to normal if I ever chose to. Then just tape up the exposed
end(s) and enjoy!
Old May 31, 2003 | 08:59 PM
jeepik's Avatar
ok update appears i was a bit wrong
on my 2k2 the clock will not dim even with the lights on and the dimmer switch does not affect it, the dash board itself will dim even at the birghtest setting
but i was right about the radio and A/C if you put the dimmer on the highest setting(make it click) the a/c and radio wont dim and will stay bright at night
hope that helps
shilov
Feb 19, 2024 09:40 PM
gavin68
Sep 18, 2021 12:36 PM
t6378tp
Sep 29, 2018 04:27 PM
vingodine
45
May 21, 2016 12:46 PM
viperboy
Sep 27, 2015 07:05 PM
