H&R spacers? 15mm - 20mm
Old Jun 3, 2003 | 10:21 AM
cmr72's Avatar
What is the impact, if any, on using these? Is it just for looks or does it affect handling in any way?
Old Jun 3, 2003 | 11:24 AM
MaxRPM's Avatar
I used them (20mm) strictly to make my OEM wheels to clear my brakes as I use them for winter.
Old Jun 4, 2003 | 10:55 AM
hanskloss's Avatar
H&R Spacers
so has anybody else put these on? I want to do it on the rear of my car, maybe 20~25mm, any issues with these? Thanks for any feedback.
Old Jun 4, 2003 | 10:58 AM
t56gen3's Avatar
I don't think there is any issue with them. But, from what pics I have seen of cars that have em, I don't think you would want to go over 20mm on each side. The 20mms look like they would rub the outer fender lip.
Old Jun 4, 2003 | 12:06 PM
cmr72's Avatar
So 20mm in the rear ONLY? Or both front & rear WITH stock rims/tires?
Old Jun 4, 2003 | 12:14 PM
t56gen3's Avatar
I'd say 20mm MAX on the rear. I have never seen anyone put them on the front. The rears are what looks funny tuckin' in so much. I'm thinking about getting the 15mm's myself. Of course, that's just a band aid--the right way to do it is get new wheels!
Old Jun 4, 2003 | 12:37 PM
cmr72's Avatar
Oh...thought they were for the front and back. So no-one puts them in the front? I thought the spacers were sold in packs of 4.
So does anyone know where to buy them? And which model number for the spacers and bolts if not included?
Old Jun 4, 2003 | 12:45 PM
hanskloss's Avatar
http://www.optauto.com/webstore/, they come in pairs of two, check out the H&R website for exact application part numbers, I think 20mm on the back will look sweet
Old Jun 4, 2003 | 01:22 PM
GaMax97GLE's Avatar
For Sale
I have 2 sets of 15mm H&R spacers for sale.
http://forums.maxima.org/showthread....hreadid=221402
Old Jun 4, 2003 | 01:58 PM
Galo's Avatar
Maxima Pilot
GaMax...You've got a PM!!
I'll send u an email as well...
galo
Old Jun 5, 2003 | 10:46 AM
hanskloss's Avatar
Final question then should I do 15mm or 20mm? I have H&R springs so car is lowered and my concern is that at 20mm the wheel might rub against that inner fender lip? any of you guys with 20mm spacers please advise on issues that you have seen with 20mm or 15mm? thank you for the input. I will post picks as soon as I get them on, but have to make the decision which ones.....thanks
Old Jun 5, 2003 | 11:32 AM
2k2nyc's Avatar
Go for the 20mm, someone else was using 25mm w/ eibachs.
Old Jun 5, 2003 | 03:47 PM
RichK's Avatar
If you want pics, go to my homepage. I use just the 20mms on the rear. I have 18s now and the spacers are still on. I may have to remove them if I want to lower it though. Hope this helps.
Old Jun 6, 2003 | 06:00 AM
juice's Avatar
Do the 20 mm slide right over the existing studs or is there alot more work invoved. I remebe someone posting that they neded new studs but i dont remeber what length it was for.
Old Jun 6, 2003 | 06:38 AM
2k2nyc's Avatar
There's a lot more work. You have to remove your brake assembly in order to do the install.
Old Jun 6, 2003 | 07:16 AM
Galo's Avatar
Maxima Pilot
I'm waiting for my 15mm spacers to arrive
from Germany..they have been on national back-order for two months now.
And I disagree with the comment that this is a band-aid to wheels as the 'real fix' because the issue here is that the front track is fine, it's the rear wheels that are too far inwards thus to cure this problem with wheels you would need wheels with a different offset for the rear wheels versus the fronts.
If you do that, then you could not rotate the tires, BTW.
Old Jun 6, 2003 | 07:26 AM
MaxRPM's Avatar
Just to clear some things up,
- You WILL need to replace your old studs with the H&R studs. Its more work, but fairly easy for those that are mechanically inclined.
- If you have wider then stock wheels/tires and lowered you WILL rub.
- If you expect more traction, forget it, you will just increase understeer if you only increase the rear track.
- If you are doing this for looks fine go for it...
Old Jun 6, 2003 | 07:36 AM
Galo's Avatar
Maxima Pilot
Hey Sam....you're definitely not a poseur so
I'm curious about ur last comment about the rear spacers increasing understeer...why would that be the case?
Old Jun 6, 2003 | 07:58 AM
hanskloss's Avatar
Thanks for all that great advice it does help in making a decision!
As far as my car I have H&R Springs, so the whip is lowered and I do have aftermarket wheels but they are the same size as original wheels. I did some measurements and the gap between my wheel and inner fender is 22.25mm, so potentialy the 20mm would be fine but with only 2.2mm to spare, that might rub, I think I will go with 15mm since my car is lowered and I shouldn't see any rubbing.
And yes I am only doing this for looks, thanks for the advice
Old Jun 6, 2003 | 08:05 AM
MaxRPM's Avatar
Re: Hey Sam....you're definitely not a poseur so
All things being equal, a wider track will increase traction. Just doing the back where we already have more then the front will just exacerbate the problem.
Old Jun 6, 2003 | 08:23 AM
t56gen3's Avatar
Re: I'm waiting for my 15mm spacers to arrive
It is a band-aid because you are adding 20mm of lug to the hub, thus creating more strain on the lugs themselves to support the weight. I've seen problems with wheel spacers before breaking lugs--it is very much a possibility. While it may work fine in most cases, it is still weaker than stock. If you get aftermarket wheels with an offset to counter the in-set spacing of the factory wheel, it will push all wheels out farther and lessen the "tuck." Get the same offset on all 4 and you can rotate endlessly. Unless of course you like how the front wheels tuck in as well.
Heh--it's your car.
Galo's Avatar
Maxima Pilot
Sam...yeah..I'm with u but...
would'nt the wider track also have the effect of lowering roll center, therefore making the tires work a wee bit harder, hence less understeer? That's what was in my head when I looked at your post...
Still
Old Jun 6, 2003 | 08:32 AM
Galo's Avatar
Maxima Pilot
T-Gen..yes, I think the fronts are fine as they
are, hence why I'm not looking to fix the problem via rims but by equalizing the look front-to-rear...
And BTW, if you get a rim offset enough to fix this 'tucked in' look in the rear, you're going to be loading the hub and everything else with close to the same load as you would with the spacers. The spacers will still create a bit more load, than rime, but not much more because the centerline of the rims would still have to be 15-20 mms farther outboard from the hub as they would be with stock rims...
That said, I too am concerned about the increased load I will be placing on the hub, rear bearings, etc, which is one of the reasons I'm going only with 15mm spacers versus what seems to be prevalent here which is either the 20 or 25mm spacers.
Old Jun 6, 2003 | 08:34 AM
MaxRPM's Avatar
Re: Sam...yeah..I'm with u but...
I'm no chassis engineer so I could be wrong but I don't think track dimensions affect the roll center. Norm Peterson (where are you) could explain this better.
But as a general rule of thumb increasing front track will reduce understeer logically increasing oversteer and vise versa.
here is something I found to back it up.
http://www.quartermidgets.com/techst...ech.html#track
Still
Old Jun 6, 2003 | 08:36 AM
t56gen3's Avatar
Re: T-Gen..yes, I think the fronts are fine as they
That's just it--ur not placing so much more load on the hub/bearing/axle, ur placing more load on the lugs themselves---they will be the first to expire under duress. Argue with me all you want, but I've seen lugs break before with 1/8 and 1/4 inch spacers, and you will be adding 1.5-2cm worth---just take it into consideration.
I'm done. Good luck.
Old Jun 6, 2003 | 08:49 AM
MaxRPM's Avatar
Re: Re: T-Gen..yes, I think the fronts are fine as they
Not with the H&R spacers, the load is carried at the hub and not the studs, which is the way it should be and how most modern wheels work.
Old Jun 6, 2003 | 08:59 AM
Galo's Avatar
Maxima Pilot
T-56...understood..hear u...thanks for your
concerns...
Old Jun 6, 2003 | 09:10 AM
MaxRPM's Avatar
I've added my H&R Spacer install pictures to my website.
http://members.rogers.com/maxrpm1/spacers.htm
These are the 20mm spacers and the longer studs were also supplied, DO NOT use these without the stud.
The H&R Kit is top notch and I haven't had a problem. Please note that I raised my suspension for the winter.
[EDIT} Please note, like most quality wheels the spacers are hub centric and do not put a load on the studs. This is the way it should be, the HUB carries the load and the studs/nuts hold you wheels.
Will there be an increase on your wheel bearings? Yes, but how much I don't know. Bigger wheels will do the same, I have yet to have a problem with the spacers in the winter and bigger wheels in the summer and I track my car 3-4 time a month which puts more load on them then you ever will on the street.
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
