Can KYB AGX's be used on are cars?
Old Jun 3, 2003 | 06:36 PM
trey
I have a friend that works at KYB and if those work he said to buy them because their ajustable. He said he can get em for me for like 100 bones for four struts.
If so are these struts preferred?
Man a lot of suspension threads going on around here?!!?
Old Jun 3, 2003 | 07:55 PM
clipse's Avatar
Re: Can KYB AGX's be used on are cars?
Only the "CATTMAN modified 4th Gen (95-99) KYB AGX Struts" will fit your 5th Gen (00-03). You'll either need to shave a little bit on your stock front upper stuts mounts or you can use 4th Gen (95-99) front upper strut mounts. Also,if your going to lower your ride. Your going to have to use 4th Gen (95-99) aftermarket lowering springs.
Old Jun 3, 2003 | 08:03 PM
trey
Re: Re: Can KYB AGX's be used on are cars?
cool, i'll stick with the gr2's
Old Jun 3, 2003 | 08:44 PM
PoLo's Avatar
2-Wheelin it...
Re: Re: Re: Can KYB AGX's be used on are cars?
i have agx's on my max, as do MANY others. the modding is all that difficult. you need to use 4th gen upper strut mounts, so that's just simple replacement. also, the the lower strut mount hole has to be expanded a bit.
for springs, it should bolt on, but if you use GC Coilovers, you have to shavea bit more.
look at it this way, normal agx modding/installation is $200. on average, agx's cost about $340 (non modified). so that's alone already $540 on just getting the job done. you're gettin them for 100, let's say you get the 200 install/mod. that's 300. you saved 240.
i say, GO FOR IT. you will love the adjustability. sometimes it's too rough and you wanna soften the ride, so do it. sometimes you want it stiff. with gr2's, what you get is waht you get, simply.
do it man, you won't regret. it' snot something to be scared about. it's been done many times to other 5th genners.
Old Jun 3, 2003 | 08:58 PM
releasedtruth's Avatar
rilla dope
Re: Re: Re: Re: Can KYB AGX's be used on are cars?
Here here, I tuned mine up to 3 in the front this morning, I felt a bit agressive on the turns and it makes a he!! of a difference
Old Jun 4, 2003 | 01:43 AM
Prodigy's Avatar
For $100 can you go wrong?
Old Jun 4, 2003 | 04:52 AM
PCGuRu2K's Avatar
That's true.. If you can get them for $100 boens that's a killer deal
Old Jun 4, 2003 | 01:52 PM
trey
thanks guys for your comments, i'm waiting for my buddy who works at kyb and whos going to install them to get home from work and tell me what he thinks also.
the main question is do i really need the adjustablility?
Old Jun 4, 2003 | 01:55 PM
PoLo's Avatar
2-Wheelin it...
depends on where you live...i live in NY. in here, i don't see how anyone can have 2front/4rear w/out getting a headache. i might go down to 1/3....up on the drive to boston, i put it 3/6 and it was stiff as hell. took turns nicely.
read that and then decide whether that pertains to you. roads, bumpy ones, can really give you a headache.
Old Jun 25, 2003 | 11:22 AM
Trev_Daddy's Avatar
5th gen KYB AGX
I thought that there was plans to bring an actual 5th gen version of the AGX to the market...What happened to these plans? I found a really good deal on 5th gen H&R Springs, but obviously, that's not going to fit very well if I want the AGX's......What happened?
T
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
