Bulbs Numbers
Old Jun 6, 2003 | 10:19 AM
SilverSleeper's Avatar
Bulbs Numbers
I would like to swap out some of my stock bulbs on my 2k3 to better match the HID's. I know that the high beam is 9005 and the fog light is H3. Could anyone tell me what the bulbs are for #1 and #2? I think #1 is a 1156 and #2 is 1157??? Also, would Piaa Xtreme Whites be a good match? Thanks for the help. *Note* I did try a seach but had no luck with a illustration.
Old Jun 6, 2003 | 10:22 AM
Igor911's Avatar
i know there is a white up somewhere in the stickies with all the bulbs and bulb #'s. Check there....
Old Jun 6, 2003 | 10:33 AM
I looked there before I posted. The only thing I saw was. I want to change the light bulbs on my car. What do I look for?. Don't think those apply.
Old Jun 6, 2003 | 10:49 AM
obiwan's Avatar
Re: Bulbs Numbers
You're in luck... I just changed my #1 and #2. The upper lamp uses a wedge type 194 or 168 bulb. I've got Polarg M4 Hyperwhites (type 194) there. I'll be switching them to PIAA Xtreme Whites shortly to match the rest of the front end. The lower lamp uses a 7440 bulb and mine now has the PIAA Xtreme White version installed. The rear turns also use the 7440 while the brake lights use the 7443 (dual filament).
HTH.
Old Jun 6, 2003 | 10:52 AM
Igor911's Avatar
Parking light
Part number = 168
Front turn signal
Part number = 7440
Rear turn signal
Part number = 7440
Tail light
Part number = 7443
Stop light
Part number = 7443
High mount stop light
Part number = 7440
License plate
Part number = 168
Back up light
Part number = 921
Upgrade Part Number = 921LL
Long Life Upgrade - Up to twice the life of the standard lamp
Front sidemarker
Part number = 194
Upgrade Part Number = 194LL
Rear sidemarker
Part number = 194
Dome light
Part number = DE3175
Step/Courtesy light
Part number = 161
Trunk/Cargo area
Part number = 158
Old Jun 6, 2003 | 11:00 AM
NT2SHBBY
what Igor said!
Old Jun 6, 2003 | 11:02 AM
Igor911's Avatar
Re: Re: Bulbs Numbers
HTH.
can i ask u a dumb question? WHY PUT A HYPER WHITE BULB BEHIND A ORANGE LENSE!? WTF
Old Jun 6, 2003 | 11:04 AM
Thanks a bunch guys, very usefull. I will be adding this info to my site soon.
Old Jun 6, 2003 | 11:05 AM
Igor911's Avatar
No problem.
Old Jun 6, 2003 | 11:32 AM
obiwan's Avatar
Re: Re: Re: Bulbs Numbers
Because I like it BETTER that way. I did check the color side by side before deciding to go with the PIAAs. Bottom line: my car, my discretionary $$$... that's WTF.
Geez, just tryin' to help the guy out...
Old Jun 6, 2003 | 11:39 AM
Igor911's Avatar
Re: Re: Re: Re: Bulbs Numbers
oooooookay
Old Jun 6, 2003 | 11:46 AM
obiwan's Avatar
Re: Re: Re: Re: Re: Bulbs Numbers
oooooookay
Man... attitude everywhere...
Old Jun 6, 2003 | 11:52 AM
maximamaybe's Avatar
PMAS76 has a good write-up. Check out his site if you want more info.
http://www.cardomain.com/member_page...224200&page=13
Old Jun 6, 2003 | 12:07 PM
obiwan's Avatar
http://www.cardomain.com/member_page...00&page=13
Thanks for posting the site. Very comprehensive on the lighting.
Old Jun 6, 2003 | 12:29 PM
That dude is a freak. In a good way of course. He loves taking pictures of his car.
Old Jun 6, 2003 | 04:03 PM
trey
so how does the hyper white look behind the orange lens?
Old Jun 6, 2003 | 04:36 PM
I was actually wondering the same thing. Any pics for comparison?
Old Jun 6, 2003 | 05:49 PM
OUMAX's Avatar
By the way, what wattage are the fogs?
Old Jun 6, 2003 | 05:56 PM
obiwan's Avatar
No pics... sorry. Several posts up there's a url with another guy's max with lot's of comparison pics. To my eye it's just a cleaner color, also a bit brighter - none of the yellowish color of the stock bulb.
What can I say... I just like it better.
Old Jun 6, 2003 | 06:02 PM
TRuFLiPpeR's Avatar
yeah, i donated....so?!?
um.....
55watts....anything higher, and you'll fry the harness. an example would be the piaa extreme white h3's part #15255. hope that helps!
n1cK!
jmlee44
Oct 2, 2022 02:13 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Noela
Sep 26, 2015 08:22 AM
