possible solution for vibrating steering wheel
Old Jun 9, 2003 | 08:58 AM
jrklar's Avatar
Just wanted to share a recent experience I had with a vibrating steering wheel. The solution was a no-brainer, but one you may not think to look for. I just installed new 18's a couple weeks ago and noticed vibrations only between speeds of 55 and 60. I figured the tires must have been out of balance so I took it to a local shop. They checked it out, tires were fine, but what actually was causing the problem was one of the centering rings had become dislodged in the installation. Car is great now, no more shaking. Like I said, easy solution, just wish I hadn't paid the $50 to have 'em look at it.
Old Jun 9, 2003 | 09:04 AM
supermanmax's Avatar
hey i installed some 18" also and i feel vibration when braking from 60-80 mph. i changed the brake pads and it lessened but but it is still there. I have a felling i need to change the rotors but i will try your suggestion first thanks.
Old Jun 9, 2003 | 10:13 AM
Dany's Avatar
I think he was talking about vibrations when driving not braking. Center rings on aftermarket wheels can cause vibration if they not correct ones, etc.
Shaking steering wheel when braking means your rotors are warped. If you have 5gen Max and under 36K, dealer should resurface rotors under warranty for you.
I just got mine done not that long ago.
Old Jun 9, 2003 | 11:23 AM
busakiller's Avatar
Re: possible solution for vibrating steering wheel
What is a centering ring?? 1st time i heard of it unless there another name for it!
Old Jun 9, 2003 | 03:22 PM
tita6's Avatar
Re: Re: possible solution for vibrating steering wheel
I think he means center cap
Old Jun 9, 2003 | 06:18 PM
Stereodude's Avatar
Negative on that one. My dealer won't do it and the car is still under warranty.
Old Jun 9, 2003 | 07:59 PM
mclee45's Avatar
they have to do it if youre complaing of that problem.. you have to know your rights..they have to fix the problem in your car the first 36k, no questions asked.. its part of hte cars warranty. they just always try to push you away first.
Old Jun 10, 2003 | 04:23 AM
busakiller's Avatar
That's true... Rotors R covered... Brakes aren't... With my Honda Accord the rotors were warped and they replaced them no ? asked but I had to pay for the brake pads... It's amazing how Nissan operates..
Old Jun 10, 2003 | 05:50 AM
jrklar's Avatar
The centering ring is different from the center cap. The centering ring is a washer-like piece that goes on the inside of the wheel. I'd attempt to explain what it does, but I'm honestly not too sure. Anyone?? I know it was the cause of my problem, cause now the car rides great again.
Old Jun 10, 2003 | 05:52 AM
PCGuRu2K's Avatar
Centering Rings are also called Huncentric Caps... There rings that go over the hub.
Well mines is not vibrating from that. It's vibrating because I have two tires in the rear with flat spots
Old Jun 10, 2003 | 06:00 AM
enicemax's Avatar
Its not true that the dealer has to resurface the rotors under warranty. The 3yr/36K unlimited warranty covers powertrain, and the rotors aren't part of the powertrain. Check the stipulations of the agreement and you'll see that. Things like the brakes and rotors are under limited warranty, so unless something that's obviously faulty with the rotors (like them falling off the bearing while the car is parked), they won't fix them. They'll say that warped rotors are just due to normal wear and tear.
Old Jun 11, 2003 | 06:23 AM
busakiller's Avatar
rotor resurface
Ummm.. This should clear up some question...
rotor resurfacing
Old Jun 11, 2003 | 06:28 AM
NT2SHBBY
thats hubcentric Danny...and when u gonna swing thru and do my fog rewire for me?
Old Jun 11, 2003 | 06:35 AM
PCGuRu2K's Avatar
You sig is huge
It's 1 wire.. I still haven't even done it on my car. Maybe I'll swing by your house or something and we'll make it a mod day
Old Jun 11, 2003 | 06:37 AM
NT2SHBBY
You sig is huge
please do!!!!!! u can clean/wax the whip in my driveway..
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
