Difference between VQ35 and VQ35DE
Old Jun 13, 2003 | 12:13 PM
BiggD23
I was just reading some older threads about oil filters. In one of them, bill99gxe mentioned that VQ35 owners should use the M1-110 filter from Mobil 1 but VQ35DE owners should use the M1-105. What is the difference between the VQ35 and the VQ35DE and how can I tell which one I have? Thanks.
Old Jun 13, 2003 | 12:17 PM
vito1281's Avatar
Re: Difference between VQ35 and VQ35DE
I think it's the same thing, just different wording. The VQ35 is the "short" name, whereas the VQ35DE is the "full" code name.
Old Jun 13, 2003 | 12:19 PM
BiggD23
Re: Re: Difference between VQ35 and VQ35DE
If that's the case then why would bill99gxe seperate the two? Like I said, he mentioned that VQ35 should use M1-110 and VQ35DE should use M1-105.
Old Jun 13, 2003 | 12:21 PM
NT2SHBBY
Re: Re: Re: Difference between VQ35 and VQ35DE
forgot to put the crack pipe down before posting??
Old Jun 13, 2003 | 12:24 PM
vito1281's Avatar
Maybe NT2SHBBY hit the nail w/his version!
Old Jun 13, 2003 | 01:02 PM
92 SE-R 02 SE
Re: Re: Re: Re: Difference between VQ35 and VQ35DE
Old Jun 13, 2003 | 02:23 PM
BiggD23
paging bill99gxe...paging bill99gxe...
Old Jun 13, 2003 | 02:26 PM
jjs's Avatar
jjs
Which thread was this?
Old Jun 13, 2003 | 02:38 PM
BiggD23
Here's the thread...
http://forums.maxima.org/showthread....hreadid=218190
And for convenience here's the part of the thread that I'm talking about...
Originally posted by bill99gxe
Use the M1-110.
The bypass valve is rated the same at 14psi, and basically the only real differences are the actual size and smaller filtration area for the M1-108 to fit in the SR20DE engine compartments.
M1-110s work on all VQ30 and VQ35 models.
Note:
For VQ35DE owners, use the M1-105 due to its better top end bypass valve design. It's better constructed than the bypass valve of the M1-108 and M1-110 filters.
Old Jun 13, 2003 | 02:43 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
The VQ35's can use either, but he's recommending the later.
Old Jun 13, 2003 | 02:46 PM
jjs's Avatar
jjs
I see the problem...it is the way you are reading this and the abbreviated form of the VQ desingations in the thread...kind of one person interchangably using Max, and Nissan Maxima to mean the exact same thing.
The way I read it is that the M1-110 will fit both, the M1-105 happens to be better for the 3.5 though. Not really a DE vs non-DE distinction...more of a 'best choice would be' comment.
As least that is the way I read this.
Old Jun 13, 2003 | 02:49 PM
F23A4's Avatar
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
