Those that change their own oil...
Old Jun 26, 2003 | 08:35 AM
BiggD23
I've done some searches and can't find anything on this topic so I'll ask. In the past I've always just taken my car to the dealership and let them do the oil+lube for $25 or whatever it costs, but since I got the Max I've been changing my own oil. The question is...what exactly is included with the lube part of oil+lube that you get at Jiffy Lube or the dealership? Is it something that we can do ourselves or should I periodically take it to the dealer and let them do just the lube? And how often should it be done? Thanks.
Old Jun 26, 2003 | 08:43 AM
sascuderi's Avatar
Correct me if I am wrong but I think Lube is an old fashion term that use to mean something (putting grease on the wheel bearings?) but now it consists of putting some grease on the door hinges and thats about it.
I have always done my own oil. Use Mobil 1, and OEM or Mobil 1 filters. When I do the change I check the level of the fluids, including the battery. If the battery is low add some distilled water. (Since I'm using Mobil 1 I change the oil/filter every 5-6K miles.)
Old Jun 26, 2003 | 11:20 AM
oldmanmax's Avatar
No lube because the wheel bearings are packed and sealed. They only lube if there's a nozzle there and most new cars don't have them now.
Old Jun 26, 2003 | 11:26 AM
BiggD23
Thanks guys.
Old Jun 26, 2003 | 11:55 AM
NT2SHBBY
they would lubricate whatever needed it....
Old Jun 26, 2003 | 02:07 PM
trey
yeah put the KY jelly away, don't need it.
Old Jun 26, 2003 | 07:53 PM
RC03MAX's Avatar
Re: Those that change their own oil...
These cars are so easy to do oil changes...I don't even have to jack the car up....I just reach in from the front passenger side tire and I can access the drain plug & filter....I have a short & wide oil catch pan (with a spout) that makes the whole process a real breeze...
Old Jun 26, 2003 | 08:21 PM
THEKNITE's Avatar
Lube
Most of the time they say they lube, but unless you stand next to them and see them do it, I doubt they lube anyway.
I do my own oil changes.
How about manual fluid change??? how easy is that?? I don't know if i should do it myself???
Old Jun 26, 2003 | 08:48 PM
saxdogg's Avatar
The lube points they talk about are on certain vehicles like trucks and 4-wheel drive things mainly now. Many cars today have sealed fittings that don't require re-lubing. Older cars had grease fittings on suspension and steering parts that required you to fill using a grease gun.
The 2k2 FSM doesn't mention lubing any parts of the chassis that I can remember.
Sorry, I'm fresh out of smart a$$ answers tonight...
ARFF
Old Jun 27, 2003 | 04:52 AM
max 01's Avatar
Lube...
Change your oil every 3k unless synthetic then you can go 5k but thats about it. Don't be misled by cars like BMW that run Mobil 1 and claim 15k. They have an 8 quart capacity so they can go longer. The Max holds right around 4. Like he said always run OEM filters and for Petes sake do it yourself. Do you realy want some high school drop out messin with your ride? I've known these guys to leave off drain plugs, put in wrong oil in the engine- they use a universal hose that also supplies tranny fluid!
Old Jun 27, 2003 | 06:35 AM
BiggD23
Re: Re: Those that change their own oil...
Huh? I don't think you understood the question, but thanks.
Old Jun 27, 2003 | 08:55 AM
bsetiawan's Avatar
Re: Lube
Very simple. You should be able to do it if you can change your own oil.
Old Jun 27, 2003 | 09:03 AM
maximo-SE's Avatar
I just came back from Jiffy lube, spent 39.99 for synthetic blend oil..... just checked walmart- mobil 1 5 quarts synthetic (18.88) plus tax, mobil one filter.... EBAY (cheap as sh*t), nissan filter 5.50. What do I say after finding this out.... nothing.... I fewel to stupid to think anymore.... but thanks a lot guys... you inspired me to do it myself.
Old Jun 27, 2003 | 11:36 AM
00MAXI's Avatar
Costco 6 pack of mobil 1 for 21.99 I think sams club has a similar deal as well
Old Jun 27, 2003 | 05:12 PM
bsetiawan's Avatar
00MAXI, may I know which Costco did you go to ? The one at Firestone Boulevard off 605 is selling 6 pack for $23.99.
Old Jun 27, 2003 | 06:01 PM
trey
Two bucks more?!??! damn inflation!
Old Jun 27, 2003 | 06:35 PM
bsetiawan's Avatar
litch
123
Jan 4, 2024 07:01 PM
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Noela
Sep 26, 2015 08:22 AM
