Franken Intake with weird noise help!
Old Jun 27, 2003 | 07:57 AM
JCW915's Avatar
Got a question guys:
Starting yesterday, between 1000 and 2800 rpms, when I step on the acclerator, I hear this high pitched whistling noise from the car. Anyone know what's wrong with it? Once it hits over 3500 rpms, the high pitch whistling noise seems to have stopped. Any advice?
Old Jun 27, 2003 | 08:39 AM
h2kFrosty's Avatar
Re: Franken Intake with weird noise help!
Those intakes do that... I think its a pretty cool sound, almost sounds like a turbo but not quite.
Bryan
Old Jun 27, 2003 | 08:42 AM
JCW915's Avatar
Ohhh. So it's normal when it sounds like something is loose in the engine compartment? Weird how when it was first installed, it didn't have that noise; until after 2 weeks of installing it, i hear that noise.
Old Jun 27, 2003 | 08:45 AM
h2kFrosty's Avatar
Try this... I noticed when I had mine installed that it only does it at a particular amount of throttle... Like when I would give it between 30-35% throttle it would make that sound but not if I had less or more than that. (and don't quote me on the amount of throttle, I'm not 100% sure). But as far as loose goes, are you hearing the whistling sound or something knocking???
Bryan
Old Jun 27, 2003 | 08:54 AM
pimpjuice's Avatar
The whistling noise is totally normal. When you have your throttle at a certain position, the throttle plate (you can see it when the intake is off, right at the beginning of the intake manifold) is at an angle where the air trying to go around it starts to whistle.
JCW915's Avatar
No knocking sound...at least not yet. The second I press down on the acclerator, doesn't matter how much is presse down, i would hear this whine/high pitch wistle then it seems to go away. Weird how it happened all of a sudden yesterday while driving on the highway. Also weird that 9 out of 10 times, i hear the sound.
Old Jun 27, 2003 | 11:40 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
yup the sound in totally normal it's caused by the design of the throttle plate. the air whistles when it's only partly open.
Old Jun 27, 2003 | 11:43 AM
JCW915's Avatar
Thanks guys
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
