Aftermarket Air Intake w/ stock scoop?
Old Jun 27, 2003 | 03:03 PM
FrankTheBunny's Avatar
I know I've seen posts where people said they left their air scoop on after putting in a new intake, but I'm wondering if anyone had to rig up anything to keep the scoop in securely?
On my '03 the scoop attaches to the front lip, and to the airbox. Without the airbox in place, the scoop is basically just hanging on the front of the car... that doesn't seem very safe.
I'd like to put the scoop back in, but I'm having a hard time trying to find a way to secure it.
Thanks...
Old Jun 27, 2003 | 03:15 PM
BiggD23
There was just a thread mentioning this the other day...I can't remember the org member's name but he left his scoop on and put some flex tubing towards the cone filter on the Frankencar. I'll try to find it...
Old Jun 27, 2003 | 03:43 PM
MannyNJ2k2max's Avatar
I left mine on ! I just seems reasonable to leave it on knowing that it probably helps direct cooler air in there as opposed to not having
it there- its hot in that mothaeffa! I might consider that flex
tubing!
Hey WEAPON R sells a kit- They call it a ram air kit designed for
their Dragon filter heads-that is basically flex tubing with
an air scoop that gets mounted behind the lower valence area
and it connects to the filter directly -wonder if it does
any justice gettin it?
BiggD23
Here you go...
http://forums.maxima.org/showthread....hreadid=227119
Old Jun 27, 2003 | 06:23 PM
Here you go...
Thanks. Although I was actually just looking for a way to secure the OEM air scoop in there, as it normally fastens to the airbox, which I've removed for my FrankenCar intake.
I ended up using a 5" corner bracket from Home Depot (god I love that store) and a couple zip-ties.
Here's a pic of my solution... sorry it's so crappy, I took it in poor light w/ my cellphone.
BkGreen97
Apr 2, 2016 05:47 AM
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
