knocking noise
Old Jun 29, 2003 | 03:02 PM
xl max03 lx's Avatar
I just started having a knocking noise come from my engine when I start the car (as the rev's come down). Why do the Maxs’ rev so much when u start it? now after i leave it for a few hours and i start it i hear a really fast knocking noise( as if the pistons are hitting something or miss firing sparks). After the start i hear no noise at all, smooth and quite ride. My friend had read something on .org about Ignition coil may have burnt out causing this noise at startup. but I don’t know if I have the same prob on a 03’. I hope this is not serious.
Old Jun 29, 2003 | 04:59 PM
dml000's Avatar
I have a 2000 that does the same thing.........not all the time though!!
Usually if it sits a few days!!
I had an oil filter that the anti drain valve was bad and it would happen every start!! Changed the filter and all better!!
Old Jun 29, 2003 | 08:32 PM
did the dealer tell you that it was a bad drain valve?
does this still happen after you changed the filter? I think i have like 400miles before oilchange so should i go earlier or wait. i just dont want any long term damage.
Old Jun 29, 2003 | 08:41 PM
E55AMG2's Avatar
Wat
Could be a bad motor mount, have the dealer check them.
Old Jun 29, 2003 | 09:15 PM
[maxi-overdose]'s Avatar
possibly timing chain rattle due to low oil pressure? tap the gas a bit and does it go away?
http://forums.maxima.org/showthread....ling+AND+start
mine happened once after letting her stayed in garage for a month without starting up the car.
Old Jun 30, 2003 | 06:41 AM
I will have to try that..Man today it sounded like a jack hammer..it was the loudest knocking i have yet heard it. I hope this is not serious now..i think im going to give the dealer a call this week. just dont have much time cause of work.
Old Jun 30, 2003 | 07:04 AM
mcfalcons15's Avatar
Similar thing happened to me recently, check out my post on page 7 called loud clicking (noise) from engine.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
