Front Window Squeek....
Old Jul 18, 2003 | 04:36 PM
max 01's Avatar
re: TSB
ITB01055
Does anyone have this TSB for my 01 max. The window noise is driving me nuts. Squeeks everytime I raise it. Yes, I've tried silicone- dealer did too...works for a few days then bam...it's back. Yes I have tint, but it doesnt squeek on any other window.
Thanks..
Dave
01 Anniv.
FSTB
Progress RSB
Old Jul 18, 2003 | 06:00 PM
MxdOut97's Avatar
i have the same problem and its been killing me too
i forgot what i sprayed, but it was something and it went away for a little but it did come back, at least its a short term solution
ill get back to you on what it was
Old Jul 18, 2003 | 10:47 PM
max 01's Avatar
Lets KIT davidpcs@optonline.net
Old Jul 20, 2003 | 10:25 PM
MuskokaPat's Avatar
I have the same problem. I find that if I clean the rubber lips that seals the top of the door to the window the squeel goes away for a few months. I use the mothers 30 day stuff. The dealer said it was because the window grommet things get excessively dirty when the windows go up and down often.
Old Jul 21, 2003 | 08:05 AM
max 01's Avatar
Thanks...
I will try it.
Old Jul 21, 2003 | 08:26 AM
CO2kmax
I had the same problem, and I also have tint on my windows. One of my good freinds works at infiniti and he does this TSB all the time. He did mine about 8 months ago and no squeaks anymore. I will ask him how he does it and I will get back too you guys.
Old Jul 21, 2003 | 08:46 AM
max 01's Avatar
That would be great if you could let me know. Do you hav a personal email address just to make sure we dont disconnect on this. It has been driving me nuts. Thanks. Mine is davidpcs@optonline.net
Dave
Old Jul 21, 2003 | 10:55 AM
Max2000's Avatar
I wants to know also.. have the same problem with tinted window and my driver side is driving me nut
Old Jul 21, 2003 | 11:24 AM
max 01's Avatar
Try this- clean the rubber on the lower window ledge frame. If that doesnt work, spray a little silicone on the lower glass and in the front track. If your under warranty let the dealer deal with it.
Old Jul 21, 2003 | 11:27 AM
THEKNITE's Avatar
Me too
It is annoying the *&^% out of me too, mostly the front passanger side. Please post the how to fix this whoever figures it out.
thnx
Old Jul 21, 2003 | 12:08 PM
GaMax97GLE's Avatar
It's not the rubber (which keeps debris from falling inside the door) that is causing the squeek. The squeek is from worn tracks that the window slides along inside the door. There was a TSB about it and your dealer should be able to fix it.
Old Jul 21, 2003 | 12:12 PM
Dany's Avatar
Damn, I had the this squeek on my 2000 SE and it drove me insane. Now on this 2002 SE I don't get the squeek, but I get this creaking sound inside the door when window goes up/down. I will have to take it and show it to dealer.
Old Jul 21, 2003 | 12:31 PM
max 01's Avatar
DOEWS ANYONE HAVE THE TSB FOR THE WINDOW SQUEEK ON A 2001 MAX?
Old Jul 21, 2003 | 12:37 PM
vito1281's Avatar
I have the same thing in my '03, and have tolerated it for about 3 months now. However, I'm getting tired of it and going to take it to the dealer.
I remember someone said that the dealer replaced the window track and the problem was fixed. That's what I'm going to tell the dealership to do.
Putting in silicone will just remedy the situation for the time being, but as the spray wears out, you'll be back at square 1.
Old Jul 21, 2003 | 12:38 PM
jttaylor155
mine squeaks and the windows are ALOT slower then they used to be. I'm thinking it is all from the same problem. The slower it is the more it squeaks!!!
Old Jul 21, 2003 | 12:43 PM
vito1281's Avatar
I just scheduled an appointment at Clay Nissan (Dedham, MA) on their web site, so waiting on their response...
Anyhow, I'm going to insist that they replace the track rather than put some lube into the existing track. I want this problem fixed permanently, and not be given a temporary solution. Hope they don't **** **** up in my car!
Old Jul 21, 2003 | 02:48 PM
CO2kmax
Ok I just talked too my budy who works at Infiniti, and he said too two things. First on the verticle runner that the window slides up and down in, spray SILICONE in the track use alot of it. Second is on the horizontial rubber protecters that stop debri from going into the door, spray CARB cleaner on a rag and wipe the rubber protectors down. Repeat this a couple of times. A couple of things he told is that this will work most of the time but NOT all of the time. He has times were he has had to order new runners for the windows. Hope that helps.
Old Jul 21, 2003 | 03:42 PM
tkostiuk4's Avatar
this also happens to me (i have tint too). it is almost as annoying as my rotors. thanks for all the help guys
Old Jul 21, 2003 | 04:03 PM
max 01's Avatar
Thanks CO2kmax I'll give it a try. The silicone works temp. I know but I never tried card cleaner.
Old Jul 21, 2003 | 04:31 PM
MAX_AE's Avatar
Wow, glad I'm not alone. When I'm rolling my windows down they pop open like they have been vacuum sealed. It scares my passengers everytime. I have to cringe before rolling my drivers side down. It screeches like a horror violin out of a Hitchcock movie.
I first tried cleaning the rubber seals with soap and water, didn't help. I then tried a glass lubricant especially for window seals that _supposedly_ doesn't get sticky. It was great at first, but after a couple of months it was sticky and made things worse. Watch out for liquid based gells. I just recently sanded the rubber down to get the film of lubricant off. My seals are dry and slick, but it still screeches something terrible. I think I'm going to try some graphite powder next. Sometimes my passenger window will not respond at all, then all of the sudden it will pop it's seal, opens and slides down, but it doesn't screech.
Old Jul 21, 2003 | 05:14 PM
max 01's Avatar
Nice car- mine is identical in everyway. 01 anniv. sterling 30% w/the squeek.
Old Jul 22, 2003 | 05:47 AM
MAX_AE's Avatar
Thanks, I like it - squeek and all.
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
jfl330
Sep 4, 2015 01:44 PM
