Help With Maintenance
I have a 02 maxima with 15k miles and got a report from the dealer to take it in for maintenance and charging $175 for it.
Automatic transmission/transaxle............periodically
Break & clutch master cylinders.............periodically
Fuel filter.................................Service as required
Power steering reservoir (1)................Inspect
Valve clearance.............................Service as required
Underbody...................................Servic e afer 12months
Air bags....................................Service after 120months
Tires.......................................Rotate
Crackcase...................................Change oil
Oil Filter..................................Change
Automatic speed control device..............Inspect
Drive Shaft boots...........................Inspect
Exhaust Systems.............................Inspect
Drive belts.................................Inspect
Brake Systems...............................Inspect
Transmission/transaxle......................Check level
Air cleaner element.........................replace
Cooling system..............................Change coolant
Fuel vapor lines............................Inspect
Steering linkage & suspension...............Inspect
As far as I can tell oil, filter,fuel & airfilter need to be replace and al far as tire rotate is all that is needed. all this other mambo jumbo like underbody,chk airbags,drive belts,valve clearance is too much for $175
. I can change the oil and other stuff for Under $175. What do you guys think?
either change the oil yourself or just have them do it if you need it. just cause its 15k does not mean you need/have to change unless its due. check the air filter itself, fuel filter is good for a while on these cars. coolant should be done around every 25-30k at least in my climate.
guess what? I took it in this morning because the service-engine-soon light has been poping up and then it goes away, so they changed a H020sensor and reprogramed the ECU and now car runs like new. All I need to do now next weekend is the oil change because it needs it and everything should be fine
Oh yeah I just got some springs to drop it but that's another story
. Oh yeah I just got some springs to drop it but that's another story
Oh check this prices out.
incabin filter $57
fuel filter $20
air filter $17
oil filter $11
Plust oil= around $115
$175 just cracks me up, they must think I own a mercedes and don't know anything about cars
incabin filter $57
fuel filter $20
air filter $17
oil filter $11
incabin filter $57
fuel filter $20
air filter $17
oil filter $11
incabin filter $57
fuel filter $20
air filter $17
oil filter $11
Re: Help With Maintenance
Any time they say "check" or "inspect" there's no way you can prove they did it.
Do it yourself. Take pride in your chariot and yourself.
Yep, see, most of the stuff is only for inspection, which means they only "take a look", sometimes they don't even inspect, they just change engine oil, filter and coolant. I think Nissan Dealer is no better than a general shop. You can get all these done by a general shop for about $100 or even less.
TKHanson
Nov 24, 2018 01:39 AM
pears
Sep 18, 2015 05:25 AM
