removal of sunroof deflector..??
Old Jul 25, 2003 | 06:44 AM
TitaniuMax03's Avatar
just a few simple questions about the sunroof deflector...how easy is it and would it leave holes on the roof where the screws connected??
Old Jul 25, 2003 | 07:03 AM
RC03MAX's Avatar
Re: removal of sunroof deflector..??
The sunroof deflector has brackets that hold it in place. But there are no holes drilled into the roof of the car. I have heard some *.org members say that the rubber gasket can rub on the paint and rough it up a bit. Just unscrew the two screws on the deflector and the brackets slide out. It's that easy.
Good Luck.
Old Jul 25, 2003 | 07:05 AM
BiggD23
It's easy, it's only 2 screws to remove. It's not screwed into the roof so there won't be any holes, it's held on by 2 brackets that sit in a little lip.
Old Jul 25, 2003 | 07:40 AM
guapsnaman's Avatar
You are going to see scratches left behind if you remove it.
Old Jul 25, 2003 | 07:50 AM
D Love's Avatar
Not necessarily. It depends on how early you remove it. I removed my deflector early on, and have no scratches. At least not visible ones.
Old Jul 25, 2003 | 08:39 AM
BiggD23
Old Jul 25, 2003 | 09:47 AM
Luquire's Avatar
I do and it really **** ****es me off
Old Jul 25, 2003 | 09:49 AM
wooord..thanks ya'll
Old Jul 25, 2003 | 09:55 AM
GhettoMAX's Avatar
aaahhh! I just put one on!
Old Jul 25, 2003 | 11:53 AM
Luquire's Avatar
take it off, take it off take it off, take it off take it off, take it off take it off, take it off
Old Jul 25, 2003 | 12:02 PM
Colonel's Avatar
Old Fuddy Duddy
NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW NOW
Old Jul 25, 2003 | 12:18 PM
GhettoMAX's Avatar
Ok I will as soon as I get home
Old Jul 25, 2003 | 01:43 PM
maxcosity's Avatar
what's wrong with leaving it on? I think it looks good? Does it look better or something?? I find that hard to believe..
Old Jul 25, 2003 | 01:45 PM
jeepik's Avatar
i like mine, works for what it was designed to do
Old Jul 25, 2003 | 01:47 PM
BiggD23
It destroys the paint on the roof. You'll have scratches after only a few months and some org members who had theirs on longer have said theirs is scratched down to the bare metal. As for the look, personally I like look of the car way better without the deflector. It's cleaner and sleeker. But look is subjective, some like the deflector and some don't.
Old Jul 25, 2003 | 02:02 PM
jonbth's Avatar
I take mine off when I wax my car, no scratches. I just use a paint cleanser and it looks like new.
Old Jul 25, 2003 | 02:07 PM
SR20DEN's Avatar
VQ Wizard
My car had less than 1000 miles on it when the parasail came off. No visible damage left behind.
Old Jul 25, 2003 | 02:12 PM
Luquire's Avatar
i have a nice 1/2 inch line that follows the pattern of the deflector and it will not go away. I did this at about 16000 miles. I do not see the need for this deflector. It causes paint problem and water/dirt always builds up in side it(i.e. on a rainy day or something like that)
Old Jul 25, 2003 | 04:01 PM
Fezzik's Avatar
Mine has been on since before i bought my car last year. Well took it off to see how bad the damage was. Yeah. i put it right back on after I put some wax on it to keep it from getting worse. It leaves a line in the paint where the gasket was, and i tried rubbing compound. The only way to fix it now is to repaint. So if u want the sunroof deflector. Be warned that it will damage ur paint unless u protect it somehow
Old Jul 25, 2003 | 08:01 PM
00MaxSE's Avatar
Pointy Elbows
Yeah I took mine off after 43K. There's a line where the gasket was but it's not bad. No scratches or anything.
J.
Mine's for sale BTW.
Old Jul 25, 2003 | 10:03 PM
well I finally took it off today..thanks for the help people...it looks soo much cleaner, especially with the drop now....I still have a leftover line of where the deflector was, but I think a little wax should fix the problem...
bigdogsteve
Jan 31, 2018 04:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
