VQ35 Exhaust manifold project
Just relocate the REAR O2-sensors from both banks behind the main cat.
The ECU is looking for a difference and without the precats it's not seeing it. I've been told you can also make a sort of "shield" around/over the O2 sensor tip to change the readings and maybe trick it.
So if the pre-cat is a seperate piece from the manifold, why couldn't we just manufacture a a piece of pipe that doesn't have the pre-cats in it?
As for the SES light, welcome to the club. My light shows up with my Y pipe when I drive at a high speed in 6th gear for a long duration at a constant speed. I've narrowed it down to the fact that the car uses the O2 sensors to adjust the air/fuel ratio. With that being said, I'm not sure if relocating the O2 sensors behind the main cat would affect the calculations or not. I'm still working on getting a properly measured Y pipe created exactly to the computer's specs, just larger.
Dixit
Originally posted by SR20DEN
My main cat is hollow too.
There is a fix for this and I will post it after I can prove it works.
Just shield the rear O2-sensors(somehow) and it will work.
I wonder if swapping a different part O2-sensor(350Z, Pathfinder, etc.) might satisfy the ECU...hmmmmmn.
Tell me you didn't gut a $700+ cat vs. buying a $35 straight pipe...
...[/B]
...[/B]
[i]
I wonder if swapping a different part O2-sensor(350Z, Pathfinder, etc.) might satisfy the ECU...hmmmmmn. [/B]
There is a fix and I willl find it.
And you are right, I drove this thing for a week before the light came on. Now it comes on within a few mins of driving as you say.
You'd have to come up with some type of "cone" shaped reducer, which might hurt flow even more.
So that means if you make the area smaller then the velocity must go up proportionally. so that is the basic idea..so NO you would not hurt your flow, you would actually speed it up a little which is good. All of this has it's limite of course so don't get any crazy ideas like a 1 inch pipe with a really high velocity, because then you can't ignore minor losses. Too big of a pipe and your air doesn't flow.
This is my basic Fluid mechanics lesson of the day, i will accept payment via paypal....you are welcome.....
Originally posted by Maxman2000
How about adding a resistor to the O2s. Or would that just make the SES light go on sooner??
My 2000 engine will have no cats.
The front can be replaced with a FED spec. 95+ manifold and using a Stillen Y-pipe. Look at DesertPearl's Cali-to-Fed spec conversion.
Originally posted by Bulldawg
Flow [Q]=VELOCITY X AREA. now we assume the flow rate is constant...that is Qin=Qout. this assumption is based on the fact that we igore minor head losses like....friction, orifice, and weirs and bends and such. (which would be created from the fragments of left over cat).
UNLESS you have a properly designed reducer, which you'll never get without modeling.
So, I still say it *MIGHT* hurt flow.
Originally posted by Thaniel
So the 3.5L and the 3.0 L have the same manifolds? Any one verify that for me? Thanks
