Poor performance 00 max
I need some serious help here with my 00 max. I hope someone has had the same problem with a solution to it. Over the past couple of months my car has been intermittantly knocking and has hesitation. One time it knocked so bad I couldn't drive over 20 mph. The stupid car didn't even throw a code! I took my car in and spent $300 on a new MAF, since that's what they said the problem was. It ran fine for a week and started again. Took the car in a second time and they blamed the K&N filter. SO i took that out and replaced with a Nissan filter. Then it was fine for a bout two weeks and has doen it again. Now Nissan tells me they don't know what to do and they won't even look at it because they can't duplicate it. Since it does it periodically it's hard to get it to do it when they have it. I saw the TSB on the hesitation and knock, but Nissan said that doesn't apply to my car. Also are the coils covered under the 60,000 mile warranty? Thanks
How many miles do you have on your Maxima?
If you're checking for any parts that may play a role in your problem,
IMO, the 1st item to check is the spark plugs. I changed mine at 40,000 miles. Nissan states it can go 100,000 before changing. But I don't think it's realistic. Since I've changed the plugs, the VQ revs smooth throughout the rev range. I changed to Autolite Platinum AP3924. BTW, I have a K&N drop-in filter that I installed at 2000 miles. It has no negative effect on the the VQ. The dealer just wants to see you use OEM parts. (and claim that if you don't it voids warranty)
I have 55,000 miles on it. The problem is that if is electrical it would just quit working. My car may do this for a couple of times one day and then not do for a week or two. Nissan America is worthless. I get the same to excuses 1. that's not covered by warranty or your just past the warranty period on that item or 2. We can't get it to duplicate the problem, which to me is just a way out. This is my first and last Nissan product. I don't see why they don't have recalls on these items that are known problems. The easiest and cheapest thing they can do is issue TSB's and hope the customer comes in after the warranty period.
Does anyone know of a way to check the coils with a multi meter or some other tool. Also the people who have had problems with the coils, was the problem intermittant or constant? Thanks for all of the suggestions and help!
Originally posted by Y2KSESteve
Check coils, change spark plugs, clean throttle body, for just a few suggestions.
Originally posted by Y2KMaxGXE-R
sorry for a stupid question, how do you clean the throttle body?
This site should have a write up with photos. I used this when I clean the TB.
JoshG
51
Sep 21, 2015 10:41 PM
Keyno McMike
Sep 21, 2015 07:18 AM
pears
Sep 18, 2015 05:25 AM
ik95
Sep 16, 2015 08:11 PM
