Painting Of Caliper's / Temperature Reccomendations!!!!
i used bbq paint...1500 degrees...i dont think you need to waste your money on high temp paint....my maxima is holding good w/ the 1500 BUT my 240sx is holding up just as good w/ its $1 paint from walmart...its not fading or melting off at all...BESIDES....$1 you can't go wrong~
Folia tech is good cause the of one word from what was mentioned above, EPOXY. Yea your $1 paint will work, how much you want a best I blast that with a jet nozzle with a standard garden hose and I can peel off a good bit of that $1 paint?
Folia tech is probably the way the to go. Just more expensive, more time consuming, but obviously results will last forever.
Dixit
Dixit
Thanks for the Information
[QUOTE]Originally posted by njmaxseltd
[B]Folia-Tech 2 Part Epoxy Caliper Painting System is the best stuff out there.
I used Plasti-Kote Brake Caliper paint with a rating of 900 degree coating. I just hope it works, if not I will put them in a pressure cleaner and strip them and redo them.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Oct 28, 2019 10:58 PM
RWCreative
Sep 21, 2015 11:01 AM
