Grinding feel at 18mph and below
Old Aug 3, 2003 | 10:13 PM
JodyBerry's Avatar
Has anyone had problems with a grinding type feeling on deceleration at about 18mph and then again about 5 mph? I've tried it in neutral, with the engine on and off and with or without the brakes applied and still the same. I had my brakes done about 4 months ago and can't remember if I felt it before. Could it be bearings?
Thanks,
Bill
Old Aug 4, 2003 | 05:38 PM
doncha's Avatar
Yea, I've got it. And I'm sick of it. Haven't been to a dealer yet. Let me know if you find out anything. My Max has been a very frustrating experience. Vibrations, broken fog lights, peeling paint on both rear door jambs, tires that can't be balanced. A real QUALITY piece of equipment. If I could afford it, it would be traded tomorrow. AND all this is on a car that has 7400 miles on it since I bought it last Oct. I tried out a '96 Subaru with 132,000 miles on it yesterday and it rode and drove better than the MAX.
Which made me feel even better. NOT.
Old Aug 4, 2003 | 07:06 PM
cabernet's Avatar
Re: Grinding feel at 18mph and below
Does it happen about 2000 RPM? This is a coomon problem with the Maximas. Shows up as a pedal vibration, roughness and lack of power around 1800-2000 RPM. So far I've seen a lot of people on here with the problem but no one with an explantion.
Old Aug 4, 2003 | 09:11 PM
JodyBerry's Avatar
<<Does it happen about 2000 RPM? This is a coomon problem with the Maximas.>>
NoIt's definitely front end somewhere - it even does it with the motor off.
Bill
Old Aug 4, 2003 | 09:19 PM
MacAlert's Avatar
How did you check for grinding with the engine off?! I thought you heard it while decelerating.
Old Aug 4, 2003 | 09:44 PM
JodyBerry's Avatar
<<How did you check for grinding with the engine off?! I thought you heard it while decelerating>>
Sorry - I guess when I said "decelerate", I meant when it was rolling to a stop. It will actually be constant if I stay right at 18 or 19mph.
And when I say grinding, I'm not talking about a loud sound I can hear. It's that feel you get holding the steering wheel and being able to feel slight vibrations (which I can only describe as a "grinding feel")
Bill
Old Aug 6, 2003 | 05:23 AM
POPO6SPD's Avatar
Yup, I've got that too. I'm not sure what it is, but it dosen't seem to be doing an damage except to my ears...
Old Aug 11, 2003 | 08:01 PM
LAArt's Avatar
This may be related to a warped rotor issue. There's a TSB out for it, which basically states that the rotors should be cut with an on-car lathe, not off the car, and there's a procedure to be followed. Take a look at the TSB sticky thread, there's a scan of this exact TSB there.
Old Aug 11, 2003 | 09:16 PM
JayMax00's Avatar
I got something like that, but it seem to start happening after I put my 18's on, I think its because of the 40 series tires. They don't absorb mutch. Do any of you have 18's?
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
