2002 short shifter
Old Aug 3, 2003 | 11:40 PM
EddiexAhn's Avatar
2002 short shifter
someone has to make one of these.
Old Aug 4, 2003 | 12:40 AM
mjg's Avatar
mjg
nah, not really... It has something to do with the linkage in the way of the transmission. Someone ellaborate please.
Old Aug 4, 2003 | 05:57 AM
SR20DEN's Avatar
VQ Wizard
I tried an over simplified version with parts from Lowes and there was not enough clearance to make it work. If I or someone else had access to a full machine shop I know one could be made.
Old Aug 4, 2003 | 06:33 AM
MattBeaty's Avatar
While we are on the topic of short throw shifters, I was wondering what a good one for a y2k would be. I know that pace setter makes one and so does Stillen. Are ther others? Which one would you guys recommned.
Old Aug 4, 2003 | 11:30 AM
PoLo's Avatar
2-Wheelin it...
don't wanna be stupid when i ask this. how's the layout of the 350 gearbox. same thing also? cause nismo has a STS for the 350's out already. yes, i know the engine mounting is differenting, but if the gearbox is the same, "shouldn't" it fit.
Old Aug 4, 2003 | 12:02 PM
SR20DEN's Avatar
VQ Wizard
The 350Z gearbox is nothing like the fwd gearbox in the Maxima. It's a rwd transmission with an output shaft that exits out the back and it's not a cable shifted unit. The FWD tramsmissions house the differential and have two axle outputs for the drive wheels.
On top of all that, Nissan virtually copied a BMW design for the 350Z transmission.
Old Aug 4, 2003 | 12:12 PM
EddiexAhn's Avatar
so with access to a machine shop a 2002 STS could possibly be made.
soooo.......who has access to a machine shop??
Old Aug 4, 2003 | 12:18 PM
MaximaMan77's Avatar
Matt do you think this would work? This is just a basic description BTW.
If you cut the shifter arm a measured amount, grind a small flat spot on it and drill a small dimple in it for a setscrew type handle. Then cut the same amount of plastic out of the sliding reverse stop, re-attach the two ends of the reverse stop using a plastic weld type product.
Old Aug 4, 2003 | 03:40 PM
MattBeaty's Avatar
maximaman777=I'm sure that could be made to work, however I would first like to find out more about some of the production STS.
So you guys have not tried any of the real shifters?
Old Aug 4, 2003 | 05:55 PM
You have a 2k Max there are shifters for you. Although, hence the title of this thread, there are not any out for 2k2+ cars.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
atriuum
Sep 28, 2015 01:19 PM
