ECM Reprogram??
Old Aug 8, 2003 | 09:28 AM
popmax's Avatar
ECM Reprogram??
New here and feeling like I'm being screwed by the service department! SES light came on - the dealer says it's a catalytic converter thing and the ECm needs to be reprogrammed.
The car is 4500 miles over warranty. The Nissan consumer service center said it wouldn't be covered even if it were still under warranty. (What does bumper-to-bumper mean??)
Anyway, I'm feeling like I shouldn't have to pay to have this done. Any advice out there? Anyone have a similar experience?
I really appreciate any help! (Although I can always just scream at the service manager!)
Becky
Old Aug 8, 2003 | 09:50 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I'm assuming 4500 over 3yr/36K, but I'd point out that it's part of the emissions system(ECU, cat, 02-sensors, etc.) and that's covered until 8yrs/80K miles according to this: http://www.epa.gov/otaq/consumer/warr95fs.txt(Credit: Galo)
I'm not sure if that's out-of-date, but I'd still try and argue it's part of the emissions system and THAT is covered for longer then the 3yr/36K.
Even if they charge you, it should only take 20-30 mins., so it won't cost but maybe, $35-$50. I know it sucks, but sometimes the fight just isn't worth the hassle.
Old Aug 8, 2003 | 09:52 AM
studman's Avatar
Catalytic Convertors are covered under the powertrain warranty, not the regular 3 year/36,000 mile warranty.
Are you over the 4 years/50,000 mile period? If so, you'll have to pay for the repairs. If not, then NNA should cover it. Call 1-800-Nissan-1 if they give you crap about it.
Old Aug 8, 2003 | 10:19 AM
popmax's Avatar
Thanks for your suggestions!! They will get me started.
They're charging me $180 so I was a little perturbed.
And in the meantime, I'm having to drive a Ford 150. I want my car back!
Thanks again!
Becky
Old Aug 8, 2003 | 10:20 AM
IceY2K1's Avatar
I doubt it's the cat convertor.
The ECU is just too sensitive and needs to be "smacked" with new limits it should accept.
Old Aug 8, 2003 | 11:03 AM
studman's Avatar
Either way... it's still covered under the powertrain warranty since the SES light code was a cat-related code. What they have to do to fix it doesn't matter, but the powertrain warranty should cover it all.
Old Aug 8, 2003 | 11:39 AM
BennysMAXIMA's Avatar
Re: ECM Reprogram??
Becky
Becky, I also had the same exact issue with my 2K SE. I called the stealership and they told me I need to have my ECM flashed with the newest software rev. Then when I actually brought it in to the Stealership they tried telling me I needed a new pre-cat. I argued/questioned the Service Advisor about this for about 35 minutes and they suddenly realized that there was a newer rev of the ECM software ($80 to update the software). They were trying to make me pay 600+ dollars for the part and 240 for installation. It has now been over 2 weeks 1K+ plus miles and the light has yet to come back on. A couple user in this forum have had the same problem and their dealer swapped out the actual CAT Converter and it went away. California Emmission cover Cat Coverters for 8 years 80K miles.
Good Luck!
Old Aug 8, 2003 | 11:48 AM
KCMichaelM's Avatar
I get nervous about this.... I bought the first 2000 Max that came into town (8/99), I have NEVER had any types of these problem. Never had any ECU issues whatsoever. I hope my ECU never goes bad because it seems like the first version of the software was the best!!!
Knock on wood
Old Aug 8, 2003 | 11:54 AM
IceY2K1's Avatar
I don't believe the powertrain warranty covers emissions equipment, but the FEDERALLY mandate emissions warranty *SHOULD*. However, she'll still have to FIGHT them inorder for them to do it at no charge, since it's not the cat. The cat is specifically listed under the emissions warranty, but the ECU is a grey area and the dealers will even argue that it's not covered under the powertrain warranty.
Although the ECU is REQUIRED for the powertrain and emissions systems to work, the dealer will still try and argue it's not covered.
aw11power
Oct 10, 2021 04:57 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
intimidator
Sep 5, 2015 07:23 PM
