WHAT IS A DREMEL (?)
Old Feb 7, 2001 | 06:20 PM
Loe max's Avatar
I was wondering what this is and how you guys used it to make your clear corners. How did you use the sandpaper and what for? What grit? what do you mean by painting the orange lense? Is it the thing where you slip in the lightbulb? or is it the inner reflector? Does the same directions apply for the rears? Can you use a blow drier to remove the orange thing to seperate it?
If I can do this, I think I'm gonna try doing altezza's
Don't care what you guys think of them
Old Feb 7, 2001 | 06:26 PM
UMD_MaxSE's Avatar
Got Bent?
Dremel is the brand of a rotary tool that has a spinning cylindrical bit on the end of it. You can put different types of bits at the end of it for sanding purposes, etc...
check http://www.dremel.com
Old Feb 7, 2001 | 07:37 PM
Loe max's Avatar
oHHHHHHHHHHH
I KNEW what it was. It just didn't come into my mind until you told me what it was. I'm SOOOOOO SLOWWWWWWW
Old Feb 7, 2001 | 08:11 PM
mdeal's Avatar
The Dremel is awesome. There are other brands, described as "rotory tools", but the Dremel may be the brand of choice. I would highly recommend one.
Old Feb 7, 2001 | 08:17 PM
djmaxski's Avatar
If you are feeling sooooooooooo slow, maybe its time for some mods other than just the clear corners... Just kidding!
Old Feb 7, 2001 | 08:39 PM
Loe max's Avatar
Cosmetics first, Internals second
I am planning to do all my cosmetics by hand. I will not spend that much money on clear lights. With the help and advice of you guys, I will surely be able to do it. I Wov you guys
Will I be able to take about the corner light assembles by using a blow drier? It seems to be stuck together (glue?). I sorta chipped alittle bit of the outside cover, but thank goodness it is at the edge where it will be covered by the bumpers and it was only on one of them
Hardest part, disassembling the dang corner to paint the reflector! arghh! I hope the rear taillights aren't this hard.
I just read about a guy making AE-like headlamps. I think I'm gonna use his procedure. I'm sure it will work with the 5th generation as with his 4th gen.
What other cosmetics after the lights? :naught: give me some ideas guys and gals!
Old Feb 7, 2001 | 08:50 PM
mdeal's Avatar
What do you mean, "I just read about a guy making AE-like headlamps."? Was this posted on maxima.org? I don't recall this.
I am presuming somebody is attempting to replicate the "bronze" look. Is this what you are referring to?
Old Feb 7, 2001 | 08:54 PM
Loe max's Avatar
Yes somewhat. Go to the General Topic. Search through the threads. It should be there. It looks quite interesting.
Old Feb 7, 2001 | 09:24 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
I don't suggest baking your headlights because they're made out of plastic... but to each their own.
Old Feb 7, 2001 | 09:28 PM
Loe max's Avatar
I had my skeptics on this one. Since your usually right, I think I'm gonna try a blow drier to remove the glue. Might take me hours, but its worth the wait.
Old Feb 10, 2001 | 05:50 PM
martinf's Avatar
Dremel is Yiddish for dream.
Old Feb 10, 2001 | 05:56 PM
MaximaZero's Avatar
Needs non-Maxima Friends
screamingvq, is your max a gle or gxe? have you popped out ur front corner assembly yet? if you have, what color is the housing? cuz on mine it's orange, but everyone else's seems to be grey..
Old Feb 10, 2001 | 06:58 PM
Loe max's Avatar
GLE, it was orange. I purchased another pair and made those first. Those had a grey housing. I made clears out of those but sold them to my uncle I just finished painting the corner lights that came with my car. I had to paint it grey, then lightly apply 3 coats of white. Orange plastic is HARD!! The edges that didn't get painted, I used liquid papper (whiteout). I used superglue to glue the clear lense to the housing at first, then this morning when I went to pop them out to paint, I just slightly hit the lense and it popped out. Word of advise, don't use superglue It does not and will not hold up in time and weather. I then used windshield/glass silicone sealant. Expensive at $6/tube. These take about an hour to dry, but I had my corners on my car within the first five minutes and drove around and It didn't fall off. Becareful, silicon is cancerous.
Old Feb 11, 2001 | 07:47 AM
greggmax's Avatar
Damn. I thought a Dremel was that thing that Jewish people spin during the Holidays.
Old Feb 11, 2001 | 08:53 AM
max2kgle526's Avatar
I think its a dradle.
Old Feb 11, 2001 | 09:25 AM
Loe max's Avatar
How is that suppost to help?
maybe when you get frustrated, you can play with the dremel (its actually called a dradle(?) and calm down?
dcam0326
Sep 26, 2015 05:20 AM
DBear
Sep 14, 2015 08:33 PM
NyC97Max
Nov 3, 2002 12:20 AM
LeoB
Jul 26, 2001 11:28 PM
ArcticMax
Feb 7, 2001 07:28 AM
