How can i remove Tar from my car?
Old 08-12-2003 | 09:10 PM
scopium
anyone got any ideas or experiences on how to remove tar from their a car?
Old 08-12-2003 | 09:13 PM
FUEL
What part of the car would help greatly
Old 08-12-2003 | 09:22 PM
scopium
lower sides of the rear bumper... the place where u get mud when u go through a puddle
Old 08-12-2003 | 09:24 PM
jay beede's Avatar
I use Ronsonal cigaret lighter fluid (naptha) in the blue and yellow can on my glacier pearl painted surfaces with excellent results. It is a very mild solvent and does not dull the clear coat on my car at all. YOUR RESULTS MAY VARY--test first on a part of the same finish but in a location that you don't mind testing on. It will also remove tar from your carpeting and plastic sill plates. If you do use the lighter fluid in your interior you might want to finish up by doing a final clean with Resolve carpet cleaner with teflon-great stuff, smells good.
Old 08-12-2003 | 09:29 PM
raymond3414's Avatar
I agree I would use just regular gasoline, it should come off with easy.
Old 08-12-2003 | 09:56 PM
mike_bresnahan's Avatar
Try a bug and tar remover for autos.
If that doesn't work try something stronger like the WATER based Goof Off! product.
Be sure to polish and wax after using any of these recommendations.
Old 08-12-2003 | 11:13 PM
AKM2k5's Avatar
soak with gasoline, and follow up with a lighted match.... always does the trick...
Old 08-12-2003 | 11:27 PM
Y2KSilvahSE's Avatar
I use "goo-gone". But like they said, make sure ya wax it afterwards.
Old 08-12-2003 | 11:29 PM
HerBlue2kSE's Avatar
Use WD-40.... wont mess with paint or plastic. Spray on, work in with your finger and wipe it off. Wash the surface after that to remove the film.
Travis
Old 08-13-2003 | 05:43 AM
Blu's Avatar
Blu
the tits
I used lighter fluid too remove VHT from the track followed by a quick coat of wax
Old 08-13-2003 | 08:14 AM
EJH Y2K SE's Avatar
Armor All has an all surface cleaner that I just used a couple of weeks ago. Worked perfect. Got it at Napa / Carquest / Target.
Old 08-13-2003 | 09:23 AM
Cutler's Avatar
Bug and Tar remover has always worked for me....
Old 08-13-2003 | 09:29 AM
brianc's Avatar
3M Adhesive remover for all of your removal needs on paint, cloth, vinyl etc...
Old 08-13-2003 | 12:18 PM
MAKSYMALNY
Some cotton ***** and either gasoline or kerosene will quickly remove it. Then remember to wash the area.
Old 08-13-2003 | 05:14 PM
Ranger Talon's Avatar
Meguire's cleaner wax has been effective for me.
Lakersallday24
06-16-2019 02:35 AM
MaximaDrvr
08-19-2015 09:20 PM
scarletsosa
08-17-2015 10:09 PM
kirkhilles
08-08-2015 11:53 AM
13Maximasv
08-07-2015 11:56 AM
