Possible Cams for VQ30DE
Old Aug 13, 2003 | 12:05 PM
MyownNismo's Avatar
Future Camaro SS owner
I e-mailed Crower Cams since on there website said that they can take a factory set of cams and make regrinds to give more HP. This is what they wrote back.
Regrind only on your stock core(s). Specs are typically 10-15 degrees more duration and .010-.015 more lift over stock. Typical HP gains are 5-15 with emphasis on top end power. Typical leadtimes are 1 week in the shop + return shipping. Cost is $78 per cam.
Crower Cams & Equipment Co Inc
3333 Main Street
Chula Vista CA 91911-5899 USA
Phone: 619-422-1191
Fax: 619-422-9067
http://www.crower.com
If anybody is interested all you have to do is take yours out and send them to them.
Old Aug 13, 2003 | 12:07 PM
3.0HO
Re: Possible Cams for VQ30DE
You must be interested or you wouldn't be posting about it right? Go ahead take them out send them in!
Old Aug 13, 2003 | 12:13 PM
SR20DEN's Avatar
VQ Wizard
Sorry but this info is a
Nealoc, Mardigrasmax and I have discussed this. Crower lists that they only take 5 thousandths off stock cams for a regrind. Not enough to make it worth your while at $78 per cam (the website said more).
Old Aug 13, 2003 | 12:14 PM
bigdo26's Avatar
think I'll leave my cams in for the moment not a bad offer from them tho
Old Aug 13, 2003 | 12:23 PM
MyownNismo's Avatar
I didn't know that.
Old Aug 13, 2003 | 12:40 PM
jjames's Avatar
5-15 horses. sorry, i'm not going to rip apart my engine and be without wheels for a week for a LIKELY 5 horses. you'd knock off more time by taking your spare out of your trunk or waxing your car.
Old Aug 13, 2003 | 12:48 PM
ejj's Avatar
ejj
How do you add duration and lift to a stock cam by re-grinding it? Maybe I'm being a little dumb, but wouldn't that require adding material to the cam?
Or would they re-grind then require you to use much larger shims on the lifters?
litch
123
Jan 4, 2024 07:01 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
