I hate my pinstripe!
Old Aug 26, 2003 | 07:53 AM
cgmaxx00's Avatar
I bought my 00 GLE in April. The originally owner put pinstipe on it. At first I though it didn't look that bad. The pinstripe is white, the car is grey luster. Now I hate it. The dealer I bought it from says I should leave it in the sun all day and then just peel. That's not cool! Does anyone know the best way, to remove this? I don't have a scratch on my car, and I don't want any flaws in the paint.
Old Aug 26, 2003 | 08:01 AM
BLKMAX005SPD's Avatar
heat up the pinstripe eitehr in the sun or get a heatgun...
Its real easy to peal off...
Then is there is any sticky stuff left on the paint get some wax and tar remover to get ride of it
Old Aug 26, 2003 | 08:04 AM
cgmaxx00's Avatar
Thanks, I'm going to try it today. I hope all the glue comes off.
Old Aug 26, 2003 | 08:26 AM
BiggD23
The question is...after 3+ years will the paint under the pinstripe be the same color as the rest of the paint? I had a white 2000 with an ugly black pinstripe that I wanted removed but the dealer said that afterwards you would most likely still be able to see where the pinstripe was because of fading.
Old Aug 26, 2003 | 08:34 AM
jesse's Avatar
VTEC This!
goo gone! go buy it at your local hardware store, stuff is great. ive taken off a few pin stripes on different cars with it
Old Aug 26, 2003 | 08:42 AM
cgmaxx00's Avatar
I never even thought of that! I don't know when the original owner put it on. I hope you can't see where the stripe was! I'm going to try anyway!
Old Aug 26, 2003 | 08:45 AM
jesse's Avatar
VTEC This!
yeah just use goo gone, take it off, get all the glue stuff off, then give it a wax in the area where it was, will look like it was never there good luck
Old Aug 26, 2003 | 08:46 AM
cgmaxx00's Avatar
Old Aug 26, 2003 | 11:13 AM
brianc's Avatar
After 3 years there will more than likely be some fading, unless the guy was a vampire and only drove at night.
You will probably have to go to a reputable detail shop and have them color sand the aree to blend in the tan lines.
Old Aug 26, 2003 | 11:20 AM
it shouldn't be to bad...
I once had a honda accord...and i took it the pin strip off and the pin strip was on for 10 years and there wasn't that much fad...
All you habve to do is after you are done give your car a good wax and it should be good as new
Old Aug 26, 2003 | 11:29 AM
jjs's Avatar
jjs
Yeah, but paint was much better back then!!
Old Aug 26, 2003 | 07:46 PM
jay beede's Avatar
Too true!!
Old Aug 26, 2003 | 11:29 PM
MaximaZero's Avatar
Needs non-Maxima Friends
I've done it before on my mom's 97 I30t. Here's what I did and it turned out great:
1. Heat up the pinstripe with a hair dryer
2. Peel off pinstripe. use a library card or something to help if needed.
3. To remover leftover glue use bug and tar remover on it.
4. I reccomend to wash and wax your car afterwards to protect the area where bug and tar remover was applied to.
Old Aug 26, 2003 | 11:37 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
i just took it off my friends 97 i30
It peeled right off, no glue left behind.
TKHanson
Nov 24, 2018 01:39 AM
JRod28
Feb 4, 2016 11:07 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
Vequity
Sep 10, 2015 05:26 AM
