strength of 2k2 auto tranny?
Originally Posted by chigga
so do you like it hombre and would u recommend doin it?
Originally Posted by hombre
sure. if you don't like it, plug it back in. I agree that it is a pretty hard 1-2 shift. It's nice to know that if you wanted to do it at the track or something you could and then undo it after. It would be cool if there was a way to put a switch in between the plugs so that you could manually switch it on/off from inside the car for those rare times that you want to get a jump at a stop light.
To get the best out of this mod, hook it up to a normally closed N/C WOT switch. That way it only works on WOT, it way too harsh for part throttle.
I have used it this way for a couple of months now and believe you get the best of both worlds faster shifts at WOT and nice soft ones at part throttle. Of course you could adjust the WOT switch as well to have it come on at part throttle wherever you want.
I'm pretty impressed - gonna go try this now I think
Maybe I can finally get Max to shift like the Silverado HD! Definatly like the feel of a firm shift, not the long pause that my Maxima has... Wish I had known about this 3 weeks ago when I went to the drags... oh well. there will be a next time.
This mod simply allows for the full line pressure for the shifts huh? So thats a good thing, right? Less resistance of the tranny fluid means its easier for the tranny to shift... but... if the shifts are harder, couldnt that shock be harmful to the tranny? or engine?
Maybe I can finally get Max to shift like the Silverado HD! Definatly like the feel of a firm shift, not the long pause that my Maxima has... Wish I had known about this 3 weeks ago when I went to the drags... oh well. there will be a next time. This mod simply allows for the full line pressure for the shifts huh? So thats a good thing, right? Less resistance of the tranny fluid means its easier for the tranny to shift... but... if the shifts are harder, couldnt that shock be harmful to the tranny? or engine?
Originally Posted by soundmike
Do you have a write-up and part numbers?
Also don't bother trying to dial in the firmness with a variable resisitor or a different sized fixed resisitor, been there, done that, it doesn't work, its either full line pressure or stock, there is no in between. I spend two days trying do the exact same thing. The idea is great but the circuit just doesn't operate like that.
BTW I have used this mod for over 2 years now but only started using the WOT idea after Deezo mentioned it. Prior to that I had it on a switch under the dash and just switched it on and off when required.
ok one last question before i try this. if its a hard shift and hear a thud ist that kind of bad for the tranny. i dont want to mess up my tranny since its a new car. also how did u ever find out about this???? thanks for the tip
just did a trial oh my car (waitin for my gf to get out of class
) this certainly does work. Under normal acceleration, the shift is firm, but a good firm. I imagine this is how a BMW shifts in sport mode or something.
My question is: WHen I went WOT, the shift did not seem faster at all... granted, I only drove my car for about 3 minutes, so the tranny wasnt nearly warmed up yet, but to those who have done this - once everything is warm, does the WOT shift feel the same as medium acceleration shifts?? Hope so, cause then I'll hafta do the splice job and hook up a switch to turn off the sensor when necessary. Great find on this modification!!!
) this certainly does work. Under normal acceleration, the shift is firm, but a good firm. I imagine this is how a BMW shifts in sport mode or something. My question is: WHen I went WOT, the shift did not seem faster at all... granted, I only drove my car for about 3 minutes, so the tranny wasnt nearly warmed up yet, but to those who have done this - once everything is warm, does the WOT shift feel the same as medium acceleration shifts?? Hope so, cause then I'll hafta do the splice job and hook up a switch to turn off the sensor when necessary. Great find on this modification!!!
I just tried it... its shifts really hard! Could this be good for the trans mounts? Its quite a loud *thud*! I would consider making a switch for it. But I have to say it shifts FASTER. I got it to chirp 2nd gear. I got a SES light after the 1st restart.... going to get the code read now.
Originally Posted by andrew3616
Everyone needs to do this!!!! I just did it to my max and it fixed the delay shift and the car felt a lot faster!!!! Serious no joke. Whoever found this thanks!!!!
Did you through any codes??
well I did it and drove for about 10 minutes...the "thud" really got to me and I didnt like it..shut the car off for about an hour and went out again, once I turned the car on guess what??? I got the DAMN SES light!!!!! So I plugged it back in turned the car off than on, still got the SES light! Well I just removed the negative terminal of my battery to reset it and still got the SES light..anyone know how else to get rid of it..I really dont recommend this but if you like "thudding" between 1-2 gear especially below 45mph..go for it..somebody help please
After reading through this thread I've thought about something. Since all you have to do is unplug this sensor and you have full line pressure, I'm sure you can mod teh HKS ALC to control everything like it does for the 300ZX A/T. To me this is just a little safer then just running without the sensor. You can actually control your shifts with that. I'll do some research and see if it's possible.
chigga, the code is P0475 - Line Pressure Sol / Circuit
Line Pressure S/V
I drove to Orlando with it
the dealer there said it was very uncommon, and that It damages the transmission, its a very unpleasant experience cause during slow driving the shift is so abrupt. He also said the plug circuit works seamlessly with the DBW system with the 2k2 and it also threw a TPS code. I was going 46 mph when the code was thrown. they have seen it happen a few times, but only on cars that were in a wreck and the resistor was busted.
It really depends on how you drive as to whether or not the 1-2 shift is hard. I've been driving with it long enough to know how much gas to give it so it doesn't slam into gear. Also, let off the gas in first gear just slightly and it should shift into 2nd without being too rough.
well I did what you said Y2KSESteve, had the battery disconnected for over an hour and still I got the light..is there any other way to reset the ECU? Did I throw a code now that only the dealer can fix..btw the car still drives fine, powerful like its always been
yeah steve, I let go of the gas a lil for the 2nd gear shift, and it was extra smooth. Im going to use it next time I goto the track..... TitaniuMax... You can let it cycle and reset itself... the battery disconnect WILL NOT work for 2k2+ models... You will have to do the Drive BY wire trick.... find "Studman" (Jeremy) he has the procedure listed on his WWW site.. or you may do a search for it.
Warrabty?
Originally Posted by Y2KSESteve
This will set off an SES light and probably will make your O/D light blink at startup. I dropped 2 tenths of a second off my ¼ mile time by just unplugging the sensor, so yes, even stock autos will benefit. A lot of people only unplug it for use at the track. I personally like the way it shifts, so I use it all the time.
Originally Posted by VMaximus02
took me a few times to get it right but it finally worked! thanx mang
I tried to reset the ECU today and I swear did exactly as those instructions said and I've tried 20 times but I'm still unable to get the SES to go away!!! What am I doing wrong? PLEASE HELP!!!
looslip, you are going to have to use a stopwatch... the timing has to be VIRTUALLY PERFECT... It takes me about 5-6 times to reset it each time. Its a pain.
Originally Posted by ][ 35
i have been driving for 2 days now unplugged and no SES yet....
this would be nice to get a switch made... anyone done that?
