WHeel spacers and studs...
Old Sep 4, 2003 | 06:47 PM
JdoubleOe703's Avatar
teddibear703
I know this was talked about before but I was wondering where I can gt wheel spacers from? I want to push out my rims about 1/2 inch to 1 inch. ALso I know that if i space out the rims I need longer studs. I remember the 300zx was said to have longer studs and fit as well. How much longer are the 300z's studs thatn our max's? Where can i buy them and are there any studs that are longer than the 300z's? thanks guys...
Old Sep 5, 2003 | 12:03 AM
irvine78's Avatar
you can buy NISMO wheel studs from Superior Nissan in Puente Hills. I think they're around $60 for a pack of 5 studs.
Old Sep 8, 2003 | 11:54 AM
teddibear703
how much extra in length do i get? thanks
Old Sep 8, 2003 | 12:59 PM
Galo's Avatar
Maxima Pilot
Typically, you would get extra length
equal to how far u wanna push the wheel out , but that said, I would not recommend that because now you have the wheel being located solely by the studs whereas with the factory setup the wheel is riding on the concentric part of the hub and all the studs are doing is afixing the wheel to the hub.
Put another way, extend with cheap spacers and longer studs only and you'll have a MUCH weaker hub/wheel assembly -which is a no-no
Look up the H&R wheel spacers and you'll see that with any spacer over 5mm, the spacer actually contains a 'replica' of the hub centering shoulder, this to ensure the load is more evenly distributed between the studs and the hub itself....
H&R spacers = good engineering, safe solution
Longer studs only = el cheapo and possibly dangerous..
Old Sep 8, 2003 | 01:24 PM
teddibear703
where can i get h&R spacers thanks
Old Sep 8, 2003 | 01:27 PM
Galo's Avatar
Maxima Pilot
here in the link attached
http://www.ecstuning.com
but, be aware these things are on national back order..have been for many months....too many us us ordered them..in my case I'm still on the back-order list.
I ordered the 15mm spacers for the rear only....
Old Sep 8, 2003 | 01:36 PM
teddibear703
do you know what size studs we have? thanks
Old Sep 8, 2003 | 01:41 PM
Galo's Avatar
Maxima Pilot
I dont know the length of our stock studs,
However, I do know the thread is 12 X 1.25, metric of course.
The H&R part number for the 15mm spacer is 3065662, BTW
Old Sep 8, 2003 | 01:51 PM
E55AMG2's Avatar
Wat
H&R makes a set of 20mm spacers that come with studs....
Old Sep 8, 2003 | 01:55 PM
soundmike's Avatar
Very sound, Mike
Would anyone know if one would need replacement studs for 5, 10 or 15mm spacers?
Would the H&R come with them if it is needed? I may get a 10mm to push my rear wheels out a bit further. What do you guys think? (pic -> http://www.nissanx.net/gall/albun09/...32535AA?full=1 )
Old Sep 8, 2003 | 01:56 PM
Galo's Avatar
Maxima Pilot
So does the 15 mm set I ordered.. For our
cars, every one of their kits where the spacer is thicker than 10mm (10, 15, 20, and 25mm kits) come with the studs.
Each and every one of them is also on national back order, I just called H&R's central US headquarters....
Old Sep 8, 2003 | 09:46 PM
teddibear703
there's a guy on ebay who makes these... what do you guys think??>?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2430834578
Old Sep 9, 2003 | 04:16 AM
RichK's Avatar
The 20mm spacers are the ones to get if you keep the factory rims. I have the 20mm on the rear and the OEM tires don't rub at all. However, with my 18s on, the rear tires rub just a bit over large dips in the road when I have 4 people in the car. Pictures are on my homepage.
Old Sep 9, 2003 | 06:13 AM
mzmtg's Avatar
Minister of Silly Walks
H&R 20mm Spacers are $100 from Options Auto Salon
http://www.optauto.com/webstore/prod...mber=HR4065662
Old Sep 9, 2003 | 06:15 AM
soundmike's Avatar
Very sound, Mike
Out of stock on all sizes for the Max.
Old Sep 9, 2003 | 06:23 AM
ICULookN's Avatar
I plan to get some 19 x 8.5 rims, which size wheel spacers do you recommend?
Old Sep 9, 2003 | 04:04 PM
teddibear703
Iculookn- you need to take the offset into consideration as well
Old Sep 10, 2003 | 04:20 AM
RichK's Avatar
I agree, the rim offset is important when considering spacers. The 18s I have are 40mm offset I think. I forget. I plan on keeping the spacers because in the winter, I am putting the OEM wheels back on with Blizzak tires. I would get the rims that you want, put them on, then decide if you even need the spacers.
Old Sep 22, 2003 | 11:25 AM
Nathan's Avatar
I have a pair of 15mm H&R wheel studs but have yet to install them b/c I'm missing 2 studs. I want to buy 2 Nismo studs but not sure which ones to get since they dont specify whether one or the other will fit the max. Can anyone tell me which one will fit?
Here's courtesynissans site:
http://www.courtesyparts.com/nismo/bolts/
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
