Exhaust Odor when travels at Highway speeds?
Old Sep 8, 2003 | 09:40 AM
mrburns's Avatar
I have a 2000 GXE and when punching the pedal or traveling on highway speeds (also slowing down from highway speeds) we tend to get an exhaust odor that comes into the car. The dealer, cleaned all the vents and replaced the O2 senor. Since the sensor was replace the smell has gotten alittle better.
With the HVAC on re-circulate the odor is stronger than if fresh air is flowing through the vents.
I have tried several different brands of gas (but not octanes) as told from the dealer and still no luck.
Has anybody had or heard of this problem?
Old Sep 8, 2003 | 10:02 AM
Maxxxed's Avatar
tEh Hope
maybe that's the rubber burning...
Old Sep 8, 2003 | 10:05 AM
BLKMAX005SPD's Avatar
My car smells too...
It smells like eggs for some reason...
i dunno what that means...but it smells like **** when i race ppl
Old Sep 8, 2003 | 10:56 AM
spirilis's Avatar
Bad catalytic converter? (ideally the check engine light should shine if that were the case) ... or maybe an exhaust leak?
Old Sep 8, 2003 | 12:17 PM
Stev02
My car smells like eggs also, when I gun it. There is no check engine light. What's up with that?
Old Sep 8, 2003 | 12:22 PM
UMD_MaxSE's Avatar
Got Bent?
clogged cat...
Old Sep 8, 2003 | 12:30 PM
Y2KSESteve's Avatar
At high speeds, make sure the A/C is off as well.
Stev02
Originally Posted by UMD_MaxSE
clogged cat...
DAMN!! That's why my car is sluggish. How do I go about unclogging? (+ I need new spark plugs, tires rotated & balanced) If I'm getting all of this done, what else should I get done? Im @ 37K miles & change. Thanks!
Old Sep 8, 2003 | 12:34 PM
Y2KSESteve's Avatar
I would also have the air filter changed out if you haven't had that done.
Old Sep 8, 2003 | 12:35 PM
UMD_MaxSE's Avatar
Got Bent?
get your dealer to replace your cat... it should be under warranty... or get a straight pipe
Old Sep 8, 2003 | 12:36 PM
mrburns's Avatar
The A/C is off. With the A/C the smell is pronounced. The dealer said that if it was the Converter then the engine light would be on. But they did say that maybe only part of the converter is have a problem thus not causing the check engine light to come on.
If it was the converter, wouldn't the smell occur when I was city driving also? This is not the case, only when getting on the highway and then when driving 75-85mph or when decelerating on the highway.
I have little kids and I'm concerned about the fumes coming into the cabin of the car.
Old Sep 8, 2003 | 06:15 PM
Stev02
Okee dokee. I will get the new air filter (b/c I need one). I will check out and see if it's a leak in exhaust or if it's the cat. If so, dealership gonna pay!
Old Sep 10, 2003 | 06:57 PM
Cdriven's Avatar
For some reason, I notice the smell a lot more w/ an intake on the car.
But, as everyone else said, only when you floor it. I thought I didn't leave enough room around the injen cai (supposively) and it was rubbin the auto cable down by the filter...
captchaos
Mar 15, 2016 12:18 PM
carid
Sep 17, 2015 05:00 AM
Bonka
Sep 14, 2015 11:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
