Humming sound after the car has been shut off.
Old Sep 9, 2003 | 07:47 PM
Cavez's Avatar
Ok, I have this really weird humming noise coming from the car after its shutoff. Its coming from the engine bay and i have no idea what it is. If anyone can shine light on this, with all means tell me what you think it is. Its worrying me quite a bit, it just started tonight.
Old Sep 9, 2003 | 07:51 PM
BLKMAX005SPD's Avatar
what kinda gas are you using?
Old Sep 9, 2003 | 07:53 PM
Cavez's Avatar
well my step mom borrowed my car and she filled it up yesterday...shes been known to do stupid stuff before. I asked her what type of gas and she said she doesnt remember. If the engine is off, it shouldnt be making any noise right? the key is out of the ignition too.
Old Sep 9, 2003 | 07:54 PM
dannodotcom's Avatar
I too have noticed a noise coming from my 2k SE after engine shutoff, but after careful listening I concluded it was coming from the rear of the car and seemed to diminish after about 2 minutes. It almost sounded like the wirring of the fuel pump, but I don't know why that would be on after engine shutdown, anybody else know???
Dannodotcom
Old Sep 9, 2003 | 07:57 PM
Cavez's Avatar
well it sounds like its coming from the fuel pump.
Old Sep 9, 2003 | 08:12 PM
Cavez's Avatar
comeon someone has to know
Old Sep 9, 2003 | 08:16 PM
redstradic's Avatar
there was a thread about this a couple of weeks ago. cant remember what it was but the guy fixed it. you should get the response pretty quickly here though
found it. here it is :
Originally posted by mdeal
The sound may be coming from the electronic controlled engine mounts. Does it sound like an electronic motor running for 5~10 seconds after turning off the car?
and heres the thread:
http://forums.maxima.org/showthread....=noise+running
Old Sep 9, 2003 | 08:28 PM
Cavez's Avatar
yeah i just read the TSB, but it looks like it could be a very expensive fix. It says to replace both engine mounts. Would that be covered under the 5year/60000 powertrain warranty? Is there a cheaper way to fix it? Im hoping so...
Old Sep 9, 2003 | 08:30 PM
Cavez's Avatar
oh and it doesnt stop, it lasts for a long time. I havent heard it stop yet. Im worried its gonna draw on the battery. I dont have computer equipment either to see if its throwing codes. For anyone that's had this problem, tell me the solution. I dont want to have to pull a fuse and keep it out.
Old Sep 9, 2003 | 08:34 PM
redstradic's Avatar
pm venompwr2, he fixed his problem, wouldnt know if its covered or not
Old Sep 9, 2003 | 08:53 PM
Cavez's Avatar
now would resetting the ECU fix this problem since the mounts are controlled by the ECU? According to the TSB, it actually requires replacing the mounts and that just seems stupid to me. Im sure the ECU has something to do with it.
Old Sep 10, 2003 | 07:19 AM
ahaling's Avatar
Cavez, my car does the same thing occasionally. I found that the humming noise is the pressure from the fuel tank being released by the gas cap. Next time you notice it, unscrew your gas cap and you'll notice the noise will go away.
Old Sep 10, 2003 | 12:27 PM
ÀÜSSÎË's Avatar
Dannodotcom
G’day,
If the noise is coming from the front I would say it is the engine mounts,
But if it is coming from the rear of the car I would bet it would be the Fuel system, as there is a charcoal canister in the rear of the vehicle to catch and store the fumes from the gas tank, this can and will come on whenever needed regardless of the ignition position.
Hop this helps…
Old Sep 10, 2003 | 01:10 PM
Cavez's Avatar
Originally Posted by ÀÜSSÎË
G’day,
Hop this helps…
well thanks for the suggestions. Im pretty sure now though that its the mounts...the only problem is that I dont want to shell out ANY money on getting it fixed right now. My battery did wear down completely overnight so this is a significant problem. I sent a message to venmpwr to see what he did but i havent received a reply so if anyone else has had this problem with the mounts, please tell me what you did to correct the problem and whether or not its covered by warranty. And if it isnt covered by warranty, how much will it cost to replace it.
Old Sep 10, 2003 | 01:51 PM
ajahearn's Avatar
Possibly a simpler answer, couldn't it be the AC compressor? I'm thinking the noise you are hearing is related to the compressed fluid warming up in the system. Have you tried turning off the AC and see if the humming goes away?
Old Oct 22, 2003 | 12:18 PM
-Red-'s Avatar
Sorry to bring this thread back to life, but I was wondering how has this been resolved. Now that I hear someone else describe it, it sonds very similar to what I'm seeing, except the sound is coming from the rear of the car. Aussie, could you point me in the direction where I can get more info on that canister thing?
Old Oct 22, 2003 | 12:24 PM
CoolMax's Avatar
is invisible
Humming? Maybe the car has a tune stuck in it's head...
Old Oct 22, 2003 | 12:42 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the noise is coming from the electronically controlled mounts. i had mine replaced from nissan per the tsb and the noise is still there. it doesnt make a sound that is very easy to describe. its not real obvious if there is any noise but if you start the car or even turn it to and then pop the hood you can hear it coming mainly from the driver side.
Old Oct 22, 2003 | 01:28 PM
-Red-'s Avatar
Hmm, going to have to listen for it again tonight.. But I could have sworn the sound was only audible from the rear of the car on the mainly at the driver's side.
Old Oct 22, 2003 | 01:47 PM
sloppymax's Avatar
if you hear something from the rear when you turn the key to on before you turn the car over, then its the whine coming from the fuel pump which is also on the drivers side. that noise is normal.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
AT978
Aug 15, 2015 06:39 PM
erniel
Aug 8, 2015 09:32 AM
maxima297
Aug 3, 2015 12:50 PM
