Hardwiring your Radar Detector
Old Sep 14, 2003 | 04:01 PM
Shogunsc4's Avatar
The link on the faq doesnt work anymore...anyone has a write up instruction?
Thanks for the help
Old Sep 14, 2003 | 09:35 PM
02MaXiMa_GLE's Avatar
I have some on my website. They're for a Bel-985.
Click on the "www" button below
G
Old Sep 14, 2003 | 10:13 PM
PCGuRu2K's Avatar
Here's the install for the V1
http://www.max-world.org/writeups/5t...ow-tos/v1.html
Old Sep 14, 2003 | 10:56 PM
krmaxima's Avatar
http://2k2maxima.freewebspace.com/catalog.html
i used this and it works great if u have the auto dimmer
Old Sep 15, 2003 | 07:32 AM
Maximus03SE's Avatar
That's pretty cool. Did you mount yours the same? I've read that mounting a radar detector that high is bad if you're pointing it through that tint band on the top of the windshield. Cuts down on the detectors effectiveness.
I'm gonna hardwire my new V1 once it gets here (bought it from PCGuRu2K; thanks again bro)
Old Sep 15, 2003 | 01:13 PM
Uconn411's Avatar
I have had no problem with my Bel 980 mounted above my rear view mirror, still does its job very well....
Old Sep 15, 2003 | 02:13 PM
hotrod37's Avatar
Wow, That seems like a lot of work just to hard wire your radar detector.
I have a 2002 max and I have had mine hard wired for over a year and a half. It is very easy to just remove the courtesy light/ sunglass fixture, take a hot lead from the hot side of the light switch and the other to ground and run them to your radar detector and re-install the assembly. The radar detector will no turn off when you turn off your car but it will turn off aprox 10 to 20 minutes after you close the last door. It draws so little power it would not make any difference if it was on all the time anyway. I hooked mine up this way the second day I had the car and it has worked fine ever since.
Old Sep 15, 2003 | 04:25 PM
maximadave's Avatar
detailerdaveb@gmail.com
me too
Old Sep 15, 2003 | 09:11 PM
asu174's Avatar
Clay Aiken has fancy genitals
I like it just below the mirror a bit better so the display is easier to read.
JRod28
Feb 4, 2016 11:07 AM
Y2KevSE
72
Aug 4, 2008 08:21 PM
RcticMax
Apr 24, 2001 04:22 PM
_DRU_
Apr 9, 2001 08:14 AM
blackY2Kmax
Jan 3, 2001 02:39 PM
