Vibration at highway speeds
Old Sep 17, 2000 | 08:34 AM
Ripper00
I have a 2k max GLE with only 300miles, but already I feel a slight vibration from the front end at highway speeds. I don't think it's rotors. Care stop very straight. Could one of my front tires be out of balance?
Old Sep 17, 2000 | 11:13 AM
TimW's Avatar
The silent but deadly Moderator
well..
it seems alot of people have warped rotors, but its more likely your tires. One thing you can walk out and check right now is the little gray dots on your rims and tires. Nissan balances them separately and marks them with a dot, then just install with the dots lined up. if you see a big diff, that might be a place to start looking.
the other problem may be that the tire just sat too long. Not a problem for tires usually, but a tire that is already marginal could be affected.
Old Sep 17, 2000 | 01:58 PM
foozed's Avatar
300 miles is a little too few to determine off the bat if its your tires or not.. At around the 1k mark, if its still happening when you drive at a constant speed, its one of two things.. tires, or axle. I doubt its the axle..
My tires were all out of whack when I picked up my 2k.. balancing, that is.
I have always had a vibration when braking from high speed though.. I thought it was a result of the unbalanced tires.. but thats been fixed forever... Now I've got 32k miles and about to replace the front brake rotors and pads with some higher end..
Old Sep 17, 2000 | 04:11 PM
SaVas's Avatar
could also be a bad tire in that the steel belts are separating (had that happen with a tire on my old maxima, and it was a new tire too). if thats the case, have it checked out and have them try to balance it. if it is separating the balancing will be difficult if not impossible I believe. Also check for tire bubble, and tight lugs
Old Sep 17, 2000 | 10:06 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Please let me know what you get. Stillen's are too small in width and I'm not sure if Powerstop has any. I want to get new pads and rotors soon. Thanks!
Old Sep 17, 2000 | 11:48 PM
mingo's Avatar
lugs
could be your lugs are loose. try to see if they are nice and tight. if you brake and don't hear or feel a thing or notice that cures the problem then that's what it is. if not it's the wheels or axles.
Old Sep 18, 2000 | 05:39 AM
PIONEER's Avatar
Reading your post. At highway Speeds, A little vibration. Sound like a balanceing problem more then anything. does it have a break in speed from which speed to which speed it happins in? meaning like b/w 50-70.. how bad is it? does the wheel start to shake a bit left to right?
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
