The CORRECT way to reset the ECU / Throttle lag cured!!!
Old Oct 23, 2003 | 09:39 AM
  #81
klapidus's Avatar
After reading through this thread, I did not see much regarding the 2k1 maxima. Just curious if this will work for a 2k1 max or is the 2k1 max just like the 2k?
Old Oct 23, 2003 | 06:38 PM
  #82
Neeferea's Avatar
It only works for 2k2 2k3
Old Oct 26, 2003 | 09:41 AM
  #83
GimmeTorq's Avatar
Originally Posted by 10e
I noticed that when I re-did it (as I had done it before the TSB on my 5-speed Altima 3.5) the throttle responds a bit differently. Before it had to seemingly reach a certain position before it would start to accelerate harder (as if it had to reach a certain "step" or a certain point in its downward progression) whereas now it seems to respond almost right away to every little change in my right foot.
Flooring it is no different but the throttle seems a bit more responsive.
Regards,
10e
Same here. Just did it today and I felt the difference in responsiveness when depressing the pedal during acceleration. I was going to take it to the dealer for the TSB work on Friday but now I may not... Let see how it keeps behaving during the week.
Props to whoever found this!!
Old Oct 26, 2003 | 11:47 AM
  #84
glen1685's Avatar
ok in have a question im installing my stillen maxima headers and y pipe also a high flow cat with greddy evo i already have a intake should i reset the ecu when im done
Old Oct 26, 2003 | 03:31 PM
  #85
kenny's Avatar
p0150n,
There is no difference using that method. That picture is from the service manual that Nissan publishes for the Maxima. The only difference is the fact that it mentions the ten flashes afterwards.
Here's the deal:
If you wait seven seconds and then press the pedal and hold it, and then wait until the SES flashes, it will give you the error codes that the computer stores. Each set of flashes is a number from 0 to 9 (with ten flashes equalling zero) and after four sets, if it flashes ten times each set (ie. between the pauses) that means the error code is 0000.
For example, if your gas cap is loose and your SES light comes on normally, and you check the error (which by the way is 0442), you will see ten flashes, a pause, four flashes, a pause, four flashes, a pause, and then two flashes.
This is useful for troubleshooting why the SES light is on, and if you have a buddy with a service manual, he can tell you the possible causes.
If there is only one error it will repeat it. If there are two, the four sets of flashes will be different.
Regards,
10e
Thanks for the posts. I have an 03 GLE and have experienced mild hesitation/lack of power since day one. I have not taken the car to the dealer for the TSB (NTB03-022 and NTB03-023) fixes, and I believe you recommend that be done in addition to the procedures for resetting the ECU. Right? I am not a techie, and I may very well ask stupid questions ... when you pump the gas pedal repeatedly, will you not flood the engine? I look forward to getting this done and enjoy my Max to its fullest potential. Upon reading the above posts (confirming the fixes and cures), I think I have a good chance ... I certainly hope so!!
Old Oct 27, 2003 | 07:13 PM
  #86
studman's Avatar
Yes, get the TSBs done.
1) Do NOT do this with the engine running.
2) The car is a drive by wire. The ECU will not allow fuel to pump into the engine unless the engine is running. You are doing nothing more than sending the ECU an electrical signal. In the 2001 and previous models, the gas pedal was connected via a cable, but in 2002+, it's done electrically instead.
Old Jan 13, 2005 | 05:34 PM
  #87
nupe's Avatar
ICEY2k1- Did this work for your 01 max? I've been looking for this thread all week. My car feels like a 82 toyota corolla right now. I have no power. Can I do these steps on my 01?
Old Jan 13, 2005 | 05:52 PM
  #88
studman's Avatar
Nope. Try searching again.
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
