2000 maxima radio problem, help
Old Sep 20, 2003 | 12:32 PM
max2000x's Avatar
hi, I'm new to max forum. Problem need to be fixed it the factory radio.
Car works great, no problem. All electronic works with the exception of the factory Radio unit, It doesn't work. No power is going to it. What could be the problem?
If you say it's the fuse, then which fuse? where is it located. need to know. thanks
Old Sep 20, 2003 | 11:57 PM
Fezzik's Avatar
There is a fuse panel under your steering wheel area a bit to the left. Should be a piece of plastic that looks like a small indentation to function as a handle. Open that, and there is a diagram telling you which one is for which electrical component of the car. Hope this helps.
Lakersallday24
Nov 7, 2024 07:31 PM
kjlouis
Nov 24, 2018 06:09 AM
jholley
Aug 11, 2015 09:38 AM
MikesChevelle
Aug 9, 2015 11:50 AM
niZ
Aug 7, 2015 10:18 PM
