2001 Maxima O2 Sensors, how many?
Originally Posted by maxi-freak
I didn't either! But now things are starting to make sense. So that would mean that there are 2 upstream and 2 downstream O2 sensors?
yeah... 2 upstream that monitor A/F ratio... 2 downstream that sit behind the precats and monitor them....
Thanks UMD~ for the info! I've tested my O2 sensors and there is only one out of the 4 that cycles from .1 to .9. If there are 2 upstream, then shouldn't both of them cycle?
the front two O2 sensors should have a relatively short cycle time... meaning they will pulse between ~0V to ~1V quickly. The downstream sensors will have a much longer cycle time. Make sure the system is in closed loop mode so that the sensors have heated up sufficiently.
OK...I guess the upstream sensor on bank 1 is bad hence the PO420, because only the front bank 2 upstream sensor cycles.
Also the rear bank downstream sensor makes no change (slow) when I induce a lean or rich condition.
Originally Posted by UMD_MaxSE
yes........
Originally Posted by Maxima Dan
Wait a second, I just replaced two on my car and there is one sticking in the front of the main cat, doesn't that monitor the cat. Or do you need one in front and one in back of the cat to monitor it?
The upstream sensor's output voltage cycles and the downstream sensors output voltages are based on lean/richness. The PCM compares the downstream sensor's output voltage with the upstream's (for it's bank) and makes the appropriate adjustment for fuel mixture - which is done by varying the pulse width for the injectors.
The way I understand it is - we have 4 o2 sensors and 3 cats. There are 2 pre-cats and 1 main cat. There is one upstream sensor for each precat and 1 downstream for each precat.
Originally Posted by OSoFast
on a 3.0 max w/ fed. spec. we have 2 up stream at either side of the exh. manifold and 1 down stream just right before the cat.
Strange how neither have an O2 sensor behind the main cat, which would be the most complete solution...
the downstream sensors are used to regulate A/F ratio only if one of the upstream sensors is bad... otherwise, they do nothing.
hehehe... a simple 555 timer circuit and some caps and resistors should be enough to make a pulse generator that simulates the O2 sensors...
Two double pole double throw switches could be used; one for bank 1 and one for bank 2. The output of each switch goes to the normal PCM IN and the inputs to the switches would be o2 sensor output OR home made circuit output. One pole input would be upstream o2 and the other would be the 555 at .1 to .9 @ 3hz. The other pole would be downstream o2 and the other would be .4vDC. So if you had a problem with bank 1...bam!.....switch the switch ...clear the code....and forget about it.
yeah but my whole thing about this is... its only if I get a CEL for removing of the precat with the new Cattman headers. If thats the case- I will need to hook up a few radioshack pieces up and make up my own "cat" in a chipset :P I'm not removing the O2 sensors.
So BlackBird...does it sound like I have a bad cat or o2 sensor? Should BOTH my upstreams be cycling?...cause only one is. I've got the PO420.
the UPSTREAM O2s have to cycle on and on from like .9 to .1 v or so inbetween... if they stay on one spot for too long U got a lazy O2 sensor and its causing U to get ****ty gas mileage. But then again U will get a O2 sensor dettoriration code.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
District
Aug 15, 2015 08:23 PM
yat70458
Aug 3, 2015 01:16 PM
I didn't know that, Maaf karna bhai
quiet exploder boy
