Stllen Drilled Rotors - Anyone Used Them
Old Sep 24, 2003 | 12:55 PM
Jopa416's Avatar
I'm considering Stillen drilled rotors as a replacement to the stock on 2001 SE AE.
Anyone ever use these?
Opinions?
Other brands liked better?
Old Sep 24, 2003 | 02:06 PM
Maximam's Avatar
Opinions?
I have them and they are a bit better than stock. They look better then they perform.
Old Sep 24, 2003 | 03:26 PM
Padsy's Avatar
Boost.....
+2
Old Sep 24, 2003 | 03:53 PM
ToYLeT902's Avatar
JET Speed Lab
i heard they crack
Old Sep 24, 2003 | 05:14 PM
Igor911's Avatar
they crack....i have a set outside by the trash. Actually make that 2 sets!
Old Sep 24, 2003 | 05:34 PM
Maximam's Avatar
My next upgrade will not be just rotor replacements
Old Sep 24, 2003 | 05:37 PM
Padsy's Avatar
Boost.....
Mine have worked fine....12K miles and counting.
Old Sep 24, 2003 | 09:17 PM
twinpower's Avatar
Just fine here
25k miles on my stillen (which actually, are brembo rotors... it's etched into the rotor) cross-drilled, and no problems.
Don't know if they perform any better than stock, I had new pads and stainless steel lines put in at the same time...
Looks cool
Old Sep 25, 2003 | 06:03 AM
Jer's Avatar
Jer
Slight hairline cracks are "normal" around the drilled areas - you'll see that over time if you push your brakes to their limits.
I've had mine for quite some time now (they've outlived the factory ones a twofold so far). Also, they're a little thicker than stock which helps..
Old Sep 25, 2003 | 11:48 AM
Jopa416's Avatar
Thanks for replies
Thanks for the replies, I don't race the car or push the brakes to the limits. I just have never felt that this car stopped very quickly and was hoping to improve stopping power without spending $2500.00 on a major upgrade.
I'll take your comments under advisement.
FYI, I did the driving light rewire - very happy with the results.
Old Sep 25, 2003 | 11:52 AM
Igor911's Avatar
you mean foglight?
Old Sep 25, 2003 | 11:54 AM
Jopa416's Avatar
Yes
Originally Posted by Igor911
you mean foglight?
Driving light/Foglight - I use the terms interchangably.
Apr 16, 2020 05:15 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
dcam0326
Sep 18, 2015 04:52 PM
A32goldylocks
Sep 2, 2015 06:39 AM
