Speaker Question for 5th Gen
Old Sep 30, 2003 | 03:44 PM
str8max's Avatar
What ohm are the speaker in the doors?
Old Sep 30, 2003 | 03:46 PM
redstradic's Avatar
4 i believe
Old Sep 30, 2003 | 03:55 PM
ZIPPIN's Avatar
Mauja He Mauja
bose or non?
Old Sep 30, 2003 | 04:12 PM
Igor911's Avatar
Bose is 2 OHM and non-bose is 4.
Old Sep 30, 2003 | 04:34 PM
str8max's Avatar
Sorry guys its a bose!
I talked to crutchfield and they said it was 4 ohm I was not sure cause I heard so many different things.
Old Sep 30, 2003 | 06:33 PM
Igor911's Avatar
I repeate, BOSE IS 2 OHM!
Old Sep 30, 2003 | 07:10 PM
Newman's Avatar
anyone care to give a layman's definition of what an ohm is? im just kind of curious since i know nothing about audio.
Old Sep 30, 2003 | 07:13 PM
swallac2
Ohm is a measure of resistance. 4 Ohm is more resistance than 2 ohm. Home speakers are usually 8 ohms, cars are normally 4. Bose feels they are special so they built it for 2.
Old Sep 30, 2003 | 09:28 PM
iLLin-2k1's Avatar
Old Sep 30, 2003 | 10:55 PM
Newman's Avatar
which is preferable? more or less? or does it depend on the application?
Old Oct 1, 2003 | 10:20 AM
swallac2
To be honest, i'm not completely sure in terms of speakers. Just thinking out loud I would think that a lower resistance speaker would be more sensitive, but wouldn't hold up as well (distort or blow up) at high volumes (because more current is allowed to pass through it). If you look at car amps, some say 2ohm or even 1 ohm stable. This is because the lower the ohm rating on the speaker, the hotter the amp will run.
I am also assuming that Bose does 2 ohms to that they can place a tweeter and a mid in series and get a 4 ohm load. (resistors add when in series).
I'm not an audio guy so I could be off on a couple of these comments.
Old Oct 1, 2003 | 10:49 AM
str8max's Avatar
I pulled out my tweeter and it has 4 ohms on the back of it!
So whats up with that?
Old Oct 1, 2003 | 10:53 AM
Igor911's Avatar
Correct,
On a bose system, speakers in the doors and the sub in the back is 2 ohm. The tweeters are 4 ohm
Old Oct 1, 2003 | 10:57 AM
subdocmax's Avatar
the twets are 4ohm as for what you are looking to do with this and need som info on this best to give me a call at 480-510-3420 and I can prob help you out on this my name is David at subsolutions
Old Oct 1, 2003 | 11:15 AM
spirilis's Avatar
As far as "what's better", I'm not sure... I think the resistance (or impedance, actually, which is resistance produced by different methods like inductive/capacitive reactance) has more to do with the magnet/driver. Maybe some research (try google) could reveal how lower impedance vs. higher impedance speaker drivers compare.
Old Oct 1, 2003 | 11:47 AM
str8max's Avatar
Thanks Guys for all the help I talked to David and is a great help to the forum!
Old Oct 1, 2003 | 11:51 AM
Igor911's Avatar
are you the guy who made the box to fit in the stock sub location?
Old Oct 1, 2003 | 07:01 PM
swallac2
Ah, someone was paying attention in his electronics class. I kinda was, but it's been almost 8 years since I had an analog class. They were a prereq.
MikesChevelle
Nov 23, 2024 11:17 AM
Matt93SE
May 24, 2019 02:58 PM
melteye
May 16, 2016 12:02 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
