Keys locked in the car
Old Feb 15, 2001 | 06:04 PM
martinf's Avatar
I got out of my Max leaving the keys in the ignition with the engine running. > did close the door. It seams it locked itself.
Is this supposed to happen? Can you not leave the car with the motor running?
Old Feb 15, 2001 | 06:19 PM
UMD_MaxSE's Avatar
Got Bent?
If the key is in the ignition and the engine is running, the doors will not lock if a door is open. I have tried this before. For example, I leave the engine running. A passenger opens the door. While the door is open, the car will not lock using the power locks. What you described.... never tried it.
Old Feb 15, 2001 | 07:17 PM
Oiprocs
same thing happened to me
During one of the bigger (first) snow storms we got here in NYC the same thing happened to me. Typically, as I do whenever it snows, I start the car first so it can warm up and help loosen up the snow/ice as I'm cleaning off the car. Of course I close the door so that no snow or ice gets inside the car. Well after about 30 minutes of cleaning the car (since we had gotten over a foot) to my surprise the doors were locked! I couldn't believe it...I had to walk all the way back to my house in a blizzard and THANKFULLY had taken the second remote out of the car (had just picked up the car that weekend!) Since that incident I have not tried to replicate that situation as I wouldn't want to be in that situation again!
Old Feb 16, 2001 | 04:01 AM
Maximizd's Avatar
Did you guys have an aftermarket alarm installed?
That doesn't sound like the default behavior for the factory entry system.
Old Feb 16, 2001 | 07:29 AM
Loe max's Avatar
bawhahaha
This happened to me twice. I thought something was wrong with my door locks. But you want to know why mine did this? Well, I found out that when I open the door, I sometimes would hit the lock mechanism on top of the door handle. When I would go and open the door, I would slightly, ever so slightly, hit it backwards triggering the lock mode and locking the door when I close the door. When I come back to the door, I would be locked out and have to call my parents to help me open it since they have the other pair. I solved this problem by unlocking ALL the doors when I get into the car, that way when the I accidentally hit the door lock mechanism when I open the door, just the drivers side would be locked and I can get in one of the passenger side.
Problem- Poor door location lock mechanism
If you don't have any clue what door lock mechanism I am talking about, I'll describe it to you. Its the one where you can push or pull it forward to lock or unlock the door manually.
Lakersallday24
Jun 16, 2019 01:35 AM
scutmud
Aug 16, 2018 10:56 AM
ah2002
Mar 9, 2016 01:42 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
kjm900r
Aug 5, 2015 07:14 AM
