I want to make my gauges brighter
Old Oct 8, 2003 | 12:27 AM
skyjay617's Avatar
I am just wondering if i replace those 168 super white wedge bulbs, will the gauges look brighter. And how many do i need??
thanks
Old Oct 8, 2003 | 12:36 AM
JdoubleOe703's Avatar
teddibear703
mee too...
Old Oct 8, 2003 | 01:05 AM
MaximaZero's Avatar
Needs non-Maxima Friends
Check out these bulbs:
http://www.superbrightleds.com/1157.htm
I'm planning on trying them out, though I've heard some issues about uneven illumination using LEDs.
Old Oct 8, 2003 | 02:27 AM
MIXXMAX's Avatar
The 168 superbright's will probably just burn the circuit board. The circuit board can only handle the bulb wattage it's designed for. As far as the 5th gener's, the bulbs are much smaller than 168/194. They are a V-2 type bulb or something. This has been discussed before but no real solution yet to get these brighter, unless you go indiglo!
Old Oct 8, 2003 | 05:45 AM
Lumbee1's Avatar
I want to keep the stock look, indiglo looks too bright and ricey. Is there anyway to put a sheet of indiglo material behind the gauge cluster and use that for lighting? I don't know if the material is sold plain and it will be a problem mounting it behind stock guage cluster. Just an idea.
Old Oct 8, 2003 | 06:01 AM
soundmike's Avatar
Very sound, Mike
I was thinking the same exact thing - using EL Strips found at SVC. I'm just not sure it'll work as planned.
Link to SVC
Old Oct 8, 2003 | 06:17 AM
Todds_max's Avatar
I did a little swapping when I installed my gauge rings and here's what I found.... First the bulbs are T-1-1/2 (glass size) with a W2.1d base. A #74 from autozone will fit just fine and is the same wattage, but the glass size is just slightly wider and longer. It fits fine but the bulb filiment is placed slightly farther from the base and makes the lighting VERY uneven. The very small difference in bulb lenght makes a very BIG difference in how the diffuser picks up and throws the light throughout the gauge. It becomes very obvious where the bulbs are located in the cluster. To keep the stock look, I think the ONLY alternative bulb would be a T-1-1/2 at a wattage of about 3.5-4. Ours are 2.3-3. This would ensure the filiment is inline with the diffuser for even disbursment with slightly higher output. Problem is I haven't been able to locate such a beast. Check out http://www.harison-toshiba.com/ for more info.
Old Oct 8, 2003 | 07:10 AM
F23A4's Avatar
Anyone know if the I35's cluster is compat with the 2K2/3 Max???
Old Oct 8, 2003 | 07:44 AM
Kojiro_FtT's Avatar
Link to SVC
That's a good idea, but too bad they aren't EL Sheets instead of strips, those look like a PITA to line up and make even.
Old Oct 8, 2003 | 07:49 AM
MaxDoogie's Avatar
no, they are not...None of the infiniti cluster's are compatible with nissans
Old Oct 8, 2003 | 08:01 AM
bremner44's Avatar
I fitted some celophane behind the guage face and now it lights up to a blue/purple. The only problem is that it's not very bright.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
