Programming remote for a 2000 GLE
Old Oct 9, 2003 | 08:31 PM
jmd102's Avatar
Hi there, new member, newer GLE in vey nice shape and was wondering how to program/ reprogram a new remote for my doorlocks etc. if I was to buy a spare one on Ebay. Many advertised. Haven't checked prices from Nissan yet. Also would anyone know the warranty with respect to rust?? I have a small blister directly beside the rear trunk lid emblem and was wondering if this would be a warranty issue?? Thanks in advance for the replies!
Mark
Old Oct 10, 2003 | 12:46 AM
ÀÜSSÎË's Avatar
G'day I hope this works,
For 1998-2002 Maxima, Pathfinder, Sentra, Altima, and Frontier Vehicles 2002 Quest and Xterra Vehicles:
1. Programming Procedure:
A. Get in the vehicle. Close and lock all doors using the driver's power door lock-unlock switch.
B. Insert and remove the ignition key more than 6 times within a 10 second period (at a rate of one insertion/removal cycle per second). The key should be withdrawn from the ignition key cylinder completely each time it is removed.
NOTE : Do not rush the insertion/removal key cycling process.
C. Turn the ignition key to the "ACC" position. The ignition key should remain in the "ACC" position throughout the remainder of the programming, including programming of additional remote controllers.
D. Press any button on the remote controller one time.
NOTE : Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
The hazard warning lights will flash twice when this step is accurately completed and programming is successful. For 2000 Quest vehicles, the side marker/tail/license lamps will flash twice when programming is successful.
E. If you are programming only one remote, proceed to step 3A. If programming additional remotes, continue with step 2A, below.
2. Programming Additional Remote Controllers (Maximum of 4 Remotes):
A. Remain inside the vehicle after programming the first remote.
B. Use the driver's power door lock-unlock switch to unlock and then lock the doors.
C. Press any button on one of the additional remote controllers one time.
The hazard warning lights will flash twice when programming is successful. For 2000 Quest vehicles, the side marker/tail/license lamps will flash twice when programming is successful.
If there is more than one additional remote to be programmed, repeat steps 2A through 2C above for each additional remote.
3. End Programming:
A. Remove the key from the ignition.
B. Use the door lock-unlock switch on the driver's door to unlock the doors. Open the driver's door to complete the programming
C. Check the operation of each of the remote controllers by locking/unlocking the doors with each remote controller you have programmed.
mclasser
22
Nov 12, 2020 01:58 PM
AaronL
Aug 8, 2020 10:31 AM
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
