2k2 Engine died - not warranteed *PICS
Old Oct 15, 2003 | 02:53 PM
  #121
Jeff92se's Avatar
I'm needing a caw
Originally Posted by IceY2K1
Your honor, we have documented service receipts that show this cars' intake had been removed and reinstalled prior to the warranty claim, thus causing the TB to fail. You think the judge would know the difference?
Yes, any judge that's not a complete moron would say that has no effect as real or not.
Exactly. Not their problem...it's his, which has now turned into a cluster *** with another engine being installed. So he's lost the ability to disprove the ORIGINAL dealers' statement that it's NOT a factory defect. He's NOW introduced too many variables to definitively prove the TB was a defect and caused the failure after the fact. He's now depending on others SCARCE evidence that there are other VQ35s out there that have failed the same.
Just getting warmed up.
The only clusterfawk is your reasoning. Again, the new engine as no bearing. Repeat and rinse. He hasn't introduced JACK SQUIDDLY DIDDLY.
Old Oct 15, 2003 | 02:55 PM
  #122
Quicksilver's Avatar
OT n00bs FTMFCSL
Jeeez...you guys are still talking about this ****!!!
Old Oct 15, 2003 | 02:58 PM
  #123
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Yep...hmmmnnnn still like the intake idea.
Originally Posted by Jeff92se
You read this yet Alex??? I don't know if you will actually understand it as it actually makes sense.
Old Oct 15, 2003 | 03:00 PM
  #124
IceY2K1's Avatar
No effect? I beg to differ and ANY judge has to accept it's possible let alone if there is a bunch of moron jurors.
Too bad my reasoning is pretty much what Nissan uses on a daily basis.
Old Oct 15, 2003 | 03:04 PM
  #125
Jeff92se's Avatar
I'm needing a caw
Holy crap. Forget it! You're contradicting yourself into bizzaro world. Even in the above case, you have one with a judge and one with Nissan. IT WON'T BE LIKE THAT. Either one or the other. Man you either don't make sense or you make things up.
Old Oct 15, 2003 | 03:06 PM
  #126
Jeff92se's Avatar
I'm needing a caw
Thank you very much
Originally Posted by hotrod37
Since they never stated that they noticed any tampering when they disassebbled the motor they can't go back now and say that he caused the problem since there is no evidence that he had ever taken apart the intake or throttle body on the car. They admit that the engine failure wase caused by the metal debris they gave him in the bag. The also told him that the motor is all alum (nice try). The only thing he has to be able prove is that those peices came from his car and the only way to prove it is to have it analyzed and have a new pin (if that is the suspect part) analyzed as well. This would be proof positive that the metal debris is the same stuff.
carl
Old Oct 15, 2003 | 03:08 PM
  #127
IceY2K1's Avatar
ASSuming Nissan is going to logically handle this is just as far fetched.
FACT: SmokinOdums' BEST scenario for the least hassle and a new engine w/warranty is to put the engine BACK, so the Nissan RR will simply say, oops you're right and he can avoid litigation.
That is my point. The rest is afternoon boredom.
Old Oct 15, 2003 | 03:09 PM
  #128
IceY2K1's Avatar
Too bad they "forgot" to check their records until they made it to court.
Thank you very much
Old Oct 15, 2003 | 03:11 PM
  #129
Jeff92se's Avatar
I'm needing a caw
Who in the hell is gonna replace a pefectly working engine with a busted up one to prove a point that has absolutely no bearing on that part of the situation????? You would do that?? You have got to be kidding me
Old Oct 15, 2003 | 03:12 PM
  #130
BiggD23
Get a room you two, we're going on the 3rd page of you guys going back and forth.
  #131
Jeff92se's Avatar
I'm needing a caw
Yep tooo bad Icy. Too bad that makes it not usable in court too.
  #132
IceY2K1's Avatar
Yes, I would to avoid ANY possibility they use it against me.
Every time I go to the dealer I remove ALL mods. No chances taken.
Old Oct 15, 2003 | 03:14 PM
  #133
IceY2K1's Avatar
Que? I don't think so.
Just because they didn't bother to check his prior service record notes has NOTHING to do with their "conclusion" at the time and is perfectly understandable for a business servicing numerous cars.
Old Oct 15, 2003 | 03:15 PM
  #134
Jeff92se's Avatar
I'm needing a caw
Too bad it wouldn't make a damn bit of difference in this case. But go ahead and replace that motor ICY. Not to mention is too damned late for that now anyway.
Old Oct 15, 2003 | 03:16 PM
  #135
Jeff92se's Avatar
I'm needing a caw
WTF was the cause ICY?? Your speculation or what the DEALER ACTUALLY SUBMITTED TO HIM?? Holy cripes Icy, I'm outa here!
Old Oct 15, 2003 | 03:17 PM
  #136
IceY2K1's Avatar
It's not too late UNLESS they've seen the junkyard engine in the car.
If they noted the intake, yes it's perfectly admissible in court and DEFINITELY too late.
Old Oct 15, 2003 | 03:19 PM
  #137
IceY2K1's Avatar
Having an aftermarket intake cause ABNORMAL unintended vibration of the throttle-body, which resulted in the butterfly screw coming loose and being injested by the engine.
  #138
Jeff92se's Avatar
I'm needing a caw
MAKES NO FAWKING DIFFERENCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
THEY ALREADY SAW THE FAWKING INTAKE!!! WTF DOES THAT HAVE TO DO WITH ANYTHING???? NNNNNOOOOOTTTTHHHHIIIIINNNNGGGGGGGGG
Old Oct 15, 2003 | 03:20 PM
  #139
Jeff92se's Avatar
I'm needing a caw
DID THEY SAY THAT?????NNNNNNOOOOOO THEY DIDN'T!!!!!!!!!!!
Having an aftermarket intake cause ABNORMAL uninteded vibration of the throttle-body, which resulted in the butterfly screw coming loose and being injested by the engine.
Old Oct 15, 2003 | 03:21 PM
  #140
Jeff92se's Avatar
I'm needing a caw
Maybe Captin Kirk beamed a few pins into the engine thus ruining the engine.
  #141
IceY2K1's Avatar
No way to prove a factory defect.
Loop-hole in court. He loses.
Old Oct 15, 2003 | 03:22 PM
  #142
Jeff92se's Avatar
I'm needing a caw
Mabe he farted into the intake and caused the pin to come loose.
  #143
IceY2K1's Avatar
Not yet, but can in court.
No way to prove NOW it didn't happen.
Old Oct 15, 2003 | 03:23 PM
  #144
IceY2K1's Avatar
Forced induction caused failure.
  #145
Jeff92se's Avatar
I'm needing a caw
Maybe he was screwing a fat chick and she knocked the pin loose.
Old Oct 15, 2003 | 03:24 PM
  #146
Jeff92se's Avatar
I'm needing a caw
Maybe ICY will perform a mind meld with the judge and convince him to rule against Smokin'
Old Oct 15, 2003 | 03:25 PM
  #147
IceY2K1's Avatar
Exceeded spring/shocks load capacity causing ABNORMAL high vibration in the TB.
Old Oct 15, 2003 | 03:29 PM
  #148
IceY2K1's Avatar
I'm not Spock(sp?).
Old Oct 15, 2003 | 03:52 PM
  #149
IceY2K1's Avatar
Your honor, we disassembled the engine to discover metal shards that were unrecognizable and determined not to be internal engine parts and thus not covered as a factory defect under the warranty. The customer was told we'd replace the engine for $XXXX, however he refused and the car was released to him upon his consent that the warranty was no longer valid with the receipt of $800 for labor. Later, we received complaints from the customer that the TB screw was missing and that this was the cause of the damage. We graciously offered to tow the car in at our expense and determine the root cause. Upon immediate delivery of the car in question, we found a different engine was installed. We no longer have the ability to determine if the screw was a factory defect. Also, according to our documented records from a DIFFERENT service department, we've discovered the factory designed intake was removed and an aftermarket one was installed. According, to our experts, the aftermarket intake was designed for "Off-road Use Only" and was inadequately designed to remove the shock and vibration attributed to normal vehicle operation. This abnormal punishment forced the throttle-body screw to break free and become injested by the engine.
We feel that this is evidence enough that there is reasonable doubt that a manufacturer defect was to blame.
Gosh I'm bored!
Old Oct 15, 2003 | 03:58 PM
  #150
Jeff92se's Avatar
I'm needing a caw
Gosh you wrote alot for nothing.
Old Oct 15, 2003 | 04:28 PM
  #151
MaxAtack's Avatar
i always wanted to see 2 moderators feud.
Old Oct 15, 2003 | 05:54 PM
  #152
MaximaMan77's Avatar
Ice if he pulls the motor and puts the junker back in then takes it in and they still feed him cow pies for lunch and this ends up going to court he's F'ed.
If the Nissan suits find out about the swap he won't stand a chance. If he perjures himself and gets caught in the lie not only will he be shown as deceitful and loose the case he may be looking at jail time.
Doing the swap in this case kind of puts him in a catch22. His best bet is to put the trashed one on a pallet and deliver it to Courtesy and start showing the evidence. Then if it goes to court he won't be lying about anything and will most likely be much more convincing because he won’t be worried about what they know or don't know.
I mean look at the Kobe case, if the hoe was really raped by him his high dollar lawyer may very well get him off. Nissan won't have to throw anywhere near that much money at this case. It's also highly unlikely this will even get that far but if he takes it there he's better off prepared.
Old Oct 15, 2003 | 07:32 PM
  #153
IceY2K1's Avatar
VQPowerSE - That isn't a "feud", it's called foreplay.
maximaman777 - VERY very true, but in this case I would take my chances on them NOT finding out about the swap. If they figure it out, I'd fess up and play Jeffs idea. I was ASSuming they wouldn't care/notice it had been removed/installed, but they might be able to tell.
Old Oct 15, 2003 | 07:33 PM
  #154
IceY2K1's Avatar
You call that "a lot"?
Wait until tomorrow when I get off dial-up.
Old Oct 16, 2003 | 01:57 AM
  #155
HitManSE's Avatar
This sucks...and just a side note: This thread would have been a whole lot simpler to read ect... if it wasnt whored up by itchy & scratchy...carry on
Old Oct 16, 2003 | 02:42 AM
  #156
mingo's Avatar
much respect for being able to pull something off in such short notice =D, glad things worked out for u man
Old Oct 16, 2003 | 04:04 AM
  #157
MaxSE03's Avatar
Great entertainment.......Took a little time off my work day! After careful consideration and respect to both parties, i will have to declare Jeff the winner.
There is nothing like getting caught up in a lie. If that happened, all credibility would be lost.
Old Oct 16, 2003 | 05:08 AM
  #158
Blu's Avatar
Blu
the tits
The itchy and scratchy shoooooooooooooooow!!!
Old Oct 16, 2003 | 05:21 AM
  #159
UMD_MaxSE's Avatar
Got Bent?
Old Oct 16, 2003 | 06:14 AM
  #160
tmuscedere's Avatar
Holy ****! I left work yesterday with only 3 pages on this thread. I get to work this morning and were at 6. I Cant wait to see what we are at by the end of the day
