Update to my PO420 issues
Old Oct 13, 2003 | 12:30 PM
maxi-freak's Avatar
Hi all,
Most people that lurk in this NG know my story. I took my car to the dealership today and told them to replace the cat on bank 1. I also let them know that I had already scoped my sensors and know that they are not bad. I reminded them that the ECU had already been updated to raise the tolerance for 3 way catalyst effeciency.
I just picked the car up. They said that they "updated the ECU". So I asked, "so this is an update to the update, cause it's already been done". They said, "exactly...and if the SES light comes back on, then we'll be replacing the cat".
Sounds pretty fishy to me. All that to say, I bet you guys will hear from me again within a couple of weeks (with a PO420).
Old Oct 13, 2003 | 01:55 PM
maximum_rpm_nyc
updated Ecu, never saw the SES again.
Old Oct 14, 2003 | 04:49 PM
maxi-freak's Avatar
Guess what? SES light back on. Called the dealership and they said that they will replace the cat next Monday.
Old Oct 14, 2003 | 06:59 PM
HitManSE's Avatar
I think...I may have found a fix for some of the injector and o2 sensor related codes, but I dont know if it ties in with PO420. The code PO171 I definetly figured out though
Old Apr 17, 2004 | 07:33 AM
irish44j's Avatar
retired moderator
so hit man, what exactly did you figure out regarding P0171? since you never posted it.....
Old Apr 17, 2004 | 08:09 AM
HitManSE's Avatar
I cant remember everything
It was a little experiment I was trying but it seems that it just post-poned the SES light from going on with the P0171 code. After hooking it up to a graphing scanner and checking out he MAF sensor. Its was pointing out that it had a weak ground. What was done to counter this was basically I spiced into the ground wire from the MAF and ran the wire to a more solid ground. I then reset the ECU and let the car go. I actually did this on about 3-4 00-01 max's and even an 01 sentra that had this problem. In about 1.5-2 months I heard from them again saying the light came back on again. So that ground I added obviously didnt work I was waiting a solid 3months be4 I posted about running another groudn to the sensor just the make sure this trick worked.
I didnt want people on the org all over to be spicing and running extra grounds to the MAF if it wasnt going to do anything. After I got those cars back I kinda got turned off it and 4got to even post about it
So basically it was an experiment I was trying but I didnt get the results I wanted. So its obvioulsly out the door. I unfourtunatley had them go to the stealership and the dealer told them they all needed new air filters
The day after the light came back on and they had to go back again. 3 of them just learned to live with the light (as I have) and 4th one is on a never ending pursuit to figure out whats going on, so I guess that about wraps things up.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
