Shift Light Install!!!
Old Oct 17, 2003 | 01:32 AM
panda_1's Avatar
I Want To Put In A Shift Light Anybody Know Which Wire On The Ecu Gives Tach Read Outs?
Old Oct 17, 2003 | 05:58 AM
fornimage's Avatar
White striped green behind the dash is more reliable.
Old Oct 17, 2003 | 07:12 AM
Igor911's Avatar
you mean behind the CLUSTER!
It's on a white connector behid the instrument cluster.
The color wire he is looking for is white/green stripe.
Good Luck
Old Oct 17, 2003 | 07:29 AM
Kojiro_FtT's Avatar
Good Luck
Or behind the glovebox coming from the ecu. Same wire. Whichever is easier for you to get at.
Old Oct 17, 2003 | 10:51 AM
maseo77's Avatar
would it be possible to install a shift light w/o the big azz tach they come with? or w/o any aftermarket tach at all?
Old Oct 17, 2003 | 10:54 AM
Igor911's Avatar
I'd like to know about this too...
I dont want any of those huge tachs. I just want the damn light
Old Oct 17, 2003 | 11:19 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Look at the Autometer shift lights. I have the bigger verison, but they have a mini version now that would fit inside your A/C vent or pretty much anywhere. Problem is they use the "RPM pills", which I found to be pretty hard to get where you want it.
They have others that don't require RPM pills like the Harlan or there is a cheapy in my Summit catalog that has a dial on the back that you set.
Old Oct 17, 2003 | 11:35 AM
Kojiro_FtT's Avatar
Lot's of options:
I wish I could remember the rest of them. There's a ton. There is another sequential one that isn't as programable as the DKS, but it looks nicer. It just lights a light at equal intervals throughout your RPM range until your programmed shift point. Trying to remember who makes it...
I actually have a Harlan RPM switch on order. I'm going to mount a single LED for the RPM switch up next to the alarm LED.
Old Oct 17, 2003 | 01:31 PM
SVTTODAMAX's Avatar
Pivot makes a mini shift light with or without digital RPM readout. The one with the RPM readout is a lot nicer.
Old Oct 17, 2003 | 01:38 PM
HondaKilLR's Avatar
If you did install it, what RPM would you set it at? Just curious........
Old Oct 17, 2003 | 09:01 PM
Maxpat82's Avatar
there's Proform one's on Ebay (35$)
Does anybody know those light??
Old Oct 18, 2003 | 12:43 AM
maximilion's Avatar
let's see.... my redline is 6600, so if you're dealing with pills, I would go for 5500. It always takes a split second for you to react once you see the light. By the time you shift from a 5500rpm pill, you'll probably be close to 6600 redline.
Old Oct 19, 2003 | 08:01 PM
panda_1's Avatar
Just To Let U Guys Know The Location Of My Tach Is Going To Be In My Driver Side Air Vent Inside It Thoughhidden From All Views. Hehe The Making Of A True Sleeper.
CorollaULEV
30
Aug 9, 2021 08:11 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
