Tranny/Clutch Problem
Old Oct 23, 2003 | 09:08 AM
Luquire's Avatar
I have been noticing that when i am slowing down from about 20-0 my car makes a winding down sound. it is high piched and it does it when i am in gear and not in gear. what is it
Old Oct 23, 2003 | 12:23 PM
Thorzdad's Avatar
Does it sound a lot like the sound your car makes when you're backing up?
Old Oct 23, 2003 | 12:26 PM
spirilis's Avatar
Low on gear oil (or have a gear oil leak)?
Sit vehicle on a flat surface, get a 1/2-inch-drive breaker bar and/or ratchet, remove the filler plug, put your finger in to see if the fluid's up to the bottom of the filler plug or shortly below it... (do it with the vehicle cold, else the fluid will be SCORCHING hot)
reinstall filler plug tight... like 25ft/lbs with a torque wrench if you have one (similar tightness as oil pan's oil drain plug)
Old Oct 23, 2003 | 03:05 PM
Luquire's Avatar
I just got my gear oil replaced and and it was making that sound before i got it replaced. I have not noticed and leak in my drive way or will it just leak when i am driving. and no it does not sound like my reverse gear, much higher pitch and it winds down not up. I never hear it on the freeway or even going 45mph. i only sometimes hear it when i am slowing down. alot of times it just does it when i drive short distances.
Old Oct 23, 2003 | 06:21 PM
spirilis's Avatar
Hmmm... bad wheel bearings?
Old Oct 23, 2003 | 06:26 PM
BC_95GLE's Avatar
Could also be a bad pilot Bearing... does it make the sounds when you are getting on or off the clutch.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
