general maintenance question
Old Oct 23, 2003 | 11:41 PM
cyclecrazy55's Avatar
Do the 2k SE's need to have their valves adjusted at any time? Will it restore some power on engines with 80k miles? Thanks in advance.
Old Oct 23, 2003 | 11:59 PM
thomasd cook's Avatar
Not sure but I recommend getting the fuel injectors cleaned at 80K would make your run like it's brand new.
Old Oct 24, 2003 | 07:12 AM
Todds_max's Avatar
I'm not certain but I think our cars have hydraulic lifters and do not need adjustment. Generally, any car that requires valve lash adjustment will have that service listed in the maintenance section of the owner's manual.
Old Oct 24, 2003 | 09:52 AM
maximum007's Avatar
What is the best way to clean the injectors?
Old Oct 24, 2003 | 11:07 AM
Take it to the dealership. I've added injector cleaner at each oil change every 4,000 miles because I use synthetic oil. You will definately feel a difference.
Old Oct 24, 2003 | 02:01 PM
Y2KMaxGXE-R's Avatar
what does adding injector cleaner in the tank of gas has to do with synthetic oil?
Old Oct 24, 2003 | 02:02 PM
Igor911's Avatar
Nothing, he has been whipped by nissan service
These are the type of ppl that pay all that $ for nothing.
Old Oct 24, 2003 | 04:45 PM
whenenver I change my oil I add some injector cleaner to the tank. Normal oil changes are supposed to be at 3,000 miles. But since I use synthetic oil I change it every 4,000 miles and add the injector cleaner to the tank.
Old Oct 26, 2003 | 05:39 AM
VQ35DE's Avatar
Not true on these engines. They can be adjusted.
Old Oct 31, 2003 | 07:11 AM
Todds_max's Avatar
You are correct. I noticed that the emission/tuneup label on the underside of the hood lists the valve lash specs. They are definitely adjustable. I don't see anything in the maintenance guide regarding adjustment.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
pears
Sep 18, 2015 05:25 AM
