The oxygen sensor wires
Old Oct 27, 2003 | 07:43 PM
PhilY's Avatar
Hey guys,
I got the oxygen sensor code P0135 so I jacked up my car to see how I would remove it. I bought an oxygen sensor socket and barely got it to fit up there. However, the wires look like they are permanently attached to the sensor. I'm sure this isn't the case since it is a replacable part. So how do I remove the sensor from the wires? I haven't purchased the replacement sensor since I'm not currently sure that I'll be able to replace it myself.
BTW, what's up with the naming conventions? Why are the the sensors towards the front of the car are called "Rear" O2 sensors and vice versa? The O2 sensor that I'm trying to replace is Front O2, Bank 1. Is that before or after precat following the convention? Would you say this is before/at/or after the exhaust? I'm trying to buy the sensor from http://replacementparts.engineautoparts.com/ and these are my options. Which one is Front Bank 1?
Thanks.
Oxygen Sensor
At header pipe inlet
(RH, firewall side)
Year: 4/1999-6/2001
Oxygen Sensor
At exh. manifold outlet
(LH, radiator side) for
Calif. models
Year: 4/1999-5/2000
Oxygen Sensor
At center cat. inlet
LH (radiator side) for
Calif, models
Year: 4/1999-5/2000
Oxygen Sensor
At front cat. outlet
Calif, models
Year: 4/1999-5/2000
conansriver
Sep 11, 2015 10:26 AM
