HELP!! i hit a pothole
Old Oct 28, 2003 | 01:33 PM
Gooey's Avatar
i have stock 17's on and i hit a pothole today...now the wheels are not aligned steerin wheel has to be tilted rite to go straight...now when i put the wheel straight and went to look at the wheels...my left wheel is straight but the other wheel is tilted to the left...the top of the wheel is in more and bottom stickin out too...when i turn right soethign on that side makes a noise but when i turn left no noise...is it just a camber issue where i need a new alignment or did somehting go bad in the suspension??? please help me!!!!
Old Oct 28, 2003 | 01:38 PM
Maxxxed's Avatar
tEh Hope
looks like you got a new 03. Take it back to the dealer and pretend like you don't know what's going on. You might get yourself free alignment.
Old Oct 28, 2003 | 01:42 PM
Gooey's Avatar
well i have maxspeed springs on them and its yellow so im sure theyll blame it on them...besides they can suck my %$#@%!%@
Old Oct 28, 2003 | 03:20 PM
Gooey's Avatar
bumpty bump bump
Old Oct 28, 2003 | 03:22 PM
Igor911's Avatar
Get an alignment and pray u didnt bend a wheel
Old Oct 28, 2003 | 03:23 PM
ssheltz's Avatar
Originally Posted by Gooey
bumpty bump bump
At a minumum you will need a good alignment. I'd start with a reputable tire shop.
Old Oct 28, 2003 | 05:14 PM
Cdriven's Avatar
I agree. Since you have aftermarket springs, most dealers won't touch it without $$. Were you going fast? Damn, must have been a big a** pothole.
Old Oct 28, 2003 | 05:30 PM
Ranger Talon's Avatar
Some jurisdictions will reimburse pothole-related damages if you file a complaint. I'd find out if this is a possibility in your case.
Old Oct 28, 2003 | 09:04 PM
NYCe MaXiMa's Avatar
you may have bent a control arm aswell..
this has happened to me on my old 3rd gen max.. big pothole, slightly bent rim, one wheel sitting off center = bent control arm... needed to replace that and needed an alignment.
Old Oct 28, 2003 | 09:11 PM
Gooey's Avatar
i dont care if i bent a rim...i just hope i didnt bend anything else on the suspension...im so sad
Old Oct 29, 2003 | 06:59 AM
MaxSE2k's Avatar
I've got a similar issue - while driving my car this winter I slid into a curb. I did have an alignment afterwards, and they said they'd straighten my steering wheel... It's still off to the right a bit to drive straight. When you find the solution, please let me know!
Old Oct 29, 2003 | 07:09 AM
NT2SHBBY
check the inner part of the wheel, the outer part might be fine but the inner might be bent-has happened to me b4
Old Oct 29, 2003 | 07:12 AM
Igor911's Avatar
is that why u sold your 17" wheels?
Old Oct 29, 2003 | 07:48 AM
NT2SHBBY
my 17's were PERRRRRRRRRRRRRRR-FECT!!!!!!!!!!!!!
not a single scratch, and with 3700miles on them....ask black2000maxima, he has em now
(except for the fact that he never aligned his car after the tein drop so i assume the tires aren't perfect anymore)
Old Oct 29, 2003 | 08:02 AM
Gooey's Avatar
gona go get it alignd now
Old Oct 29, 2003 | 08:16 AM
futemv's Avatar
Happened to me on my previous 4th gen: hit some black ice going faster than i shouldve and hit a curb (luckily only that). Bent the rim, luckily it was stock and i replaced it pretty cheap. Thought that would be the end of it, but in a couple of months i heard a noise coming from the bearings in the front right on turns and had to replace it with a new axle. i dont know if it was related to the curb i hit but the mechanic said it was likely. so my point is you never know what a good hit to the wheels could screw up. Pray its just your alignment. good luck.
D Mason
Jun 21, 2016 04:43 AM
captchaos
Mar 15, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
