Problems starting car
Old Oct 28, 2003 | 11:00 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i got a problem, sometimes when i try to start my 00 max, it has a REALLY hard time starting, i hold the to turn it on, but it never starts, and keeps attempting to start( like an old bucket)......this shouldn't happen to a fairly new car that is kept under good condition....what do you think is the problem?? spark plugs?? starter?? ill take any suggestiongs. thanks!
Old Oct 28, 2003 | 11:14 PM
01SE02SER's Avatar
Faster than a speeding bullet...
Have you checked your battery's water level?
My Maxima would not start this past Sunday and it turned out to be very, very low water level in the battery's cells.
Peace.
Old Oct 28, 2003 | 11:40 PM
Maxima112's Avatar
Peace.
nope, ill check that this weekend, thanks.
Old Oct 29, 2003 | 06:15 AM
Darth Vader's Avatar
Peace.
Good call, in all likelyhood that is the original battery. It may be on its way out.
Old Oct 29, 2003 | 06:25 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i had a similar issue but it only occured after driving a short distance and trying to crank it back up after i got back. i learned through a member to just turn the key to on right before you turn it over for like 10 seconds then start the car. the condition was something close to injector leakdown. whatever it was, it solved the problem. just something else to consider.
Old Oct 29, 2003 | 09:02 AM
BlackMax97's Avatar
If your battery turns out to be low on water, make sure you add distilled water not tap. I just replaced my OEM battery with Diehard Gold.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
