Just installed HID's, Question...
Old Oct 30, 2003 | 12:26 AM
00SEinMA's Avatar
So I just installed my Osram 6000K hid's, and now that they are on, my high beam indicator is on in the dash. When I put the lever into the high beam position, it still stays on. I thought I remembered reading something about this a while back, but when I searched I couldn't find any useful info.
Any ideas or anyone run into this?
-James
Old Nov 2, 2003 | 08:05 PM
00SEinMA's Avatar
Bump... anybody?
Old Nov 2, 2003 | 08:22 PM
E55AMG2's Avatar
Wat
you may have hooked it up to the high beam circuit
Old Nov 2, 2003 | 10:07 PM
00SEinMA's Avatar
The lever for the lights is in the low beam and it was a plug and play unit... so I dunno.
Anyone who has opened the dash up, is that an easy bulb to remove?
Old Nov 3, 2003 | 06:50 AM
Igor911's Avatar
This happens with all HID aftermarket kits on 2000-2001.
Old Nov 3, 2003 | 07:52 AM
Luquire's Avatar
how are the lights. Is there noticeable glare or is it pretty focused.
Old Nov 3, 2003 | 09:19 AM
00SEinMA's Avatar
I have a friend who has a 2000 with new HID's and no high beam light on...
The lights are great, there were some hotspots, but I built shields and that took care of the problem. There is still some glare but not as bad...
Here's a pic of the beam pattern, you can see the glare, but the hotspots are gone after the shields, so the cutoff isn't too bad. The fog light bulb is my old Piaa Plazma... they sure look yellow now.
Old Nov 3, 2003 | 09:53 AM
Igor911's Avatar
Then your friend has HIGH/LOW HID conversion kit on his maxima.
Old Nov 3, 2003 | 10:55 AM
00SEinMA's Avatar
Ahh... maybe that is it... great point.
Old Nov 3, 2003 | 11:54 AM
scmaxima2k's Avatar
Im the friend 00SEinMA is talkin about. I do have a high/low kit on my 2k so that must be why i dont have the indicator light on. Thanks for clearin it up for us. James lets pull the bulb out lol.
-Steve
Old Nov 3, 2003 | 01:19 PM
carabuser's Avatar
how did y'all pay for the kit and conversion?
Old Nov 3, 2003 | 02:42 PM
jesse's Avatar
VTEC This!
i only have the one beam, and the light never came on for me
Old Nov 3, 2003 | 02:47 PM
00SEinMA's Avatar
It says in your mod list that you've got 2k3 hid's... did you just use the ballasts and the bulbs and retrofit into the 2k housing?
Old Nov 3, 2003 | 05:44 PM
AE SEoulchild's Avatar
No it doesn't.
Old Nov 4, 2003 | 05:47 AM
greekmax2k1's Avatar
i had the same problem with that....if its plug and play and there is no high beam there should be a little loop looking thing on the plug that cancels out the highbeams....mine wouldnt go off so i cut that part off and no light since....
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
